reo-ron wrote:I want to run wheels on the trailer to match the TV. It's an '06 Wrangler. Any body know what bolt pattern the newer Jeeps are using?? It's not the old 5 1/2 BC that the CJ's used. It's smaller.
reo-ron wrote:Thanks for the help!! I've already got trailers with 4 1/2 BC wheels and lots more wheels in the shed . Sooo -that problem is solved. I'm not a jeeper but a friend who borrows my teardrop wants meet to help build a trailer for her to pull that matches her jeep and has the same tire and wheel combo . That way she only needs her Jeep spare and not a trailer spare. I'm a hot rodder not an off-roader My trailers have vintage wheels that are 4-5 inches wide. Her's will have 33X12.5 15's on the trailer as well as the Jeep.
Ron
reo-ron wrote:I'll see if she's interested in any "exposure" .
Ron
LOLOasis Maker wrote:reo-ron wrote:I'll see if she's interested in any "exposure" .
Ron
Again... strictly just for higher learning of course.![]()
Scott G.
eamarquardt wrote:"Big" Guy (Teardrops for Vets) wanted Toyota rims on his trailer (to match his car). The trailer axle hub was too big for the hole in the rim so we removed the tire, put it on my milling machine, indicated it in to .001, and bored it out so that the rim would slip over the hub. Worked fine. But, as the trailer axle hub was deeper than the Toyota hub we couldn't fit the hubcap on.
Any machine shop could do this for you I'd expect it would take a couple of hours max and shop rates run maybe $100/hour.
Gus
