Tandum axle split
Tandum axle split
Postby GaryW » Sat Feb 06, 2010 12:17 pm
I have a frame with Tandum axle from a 19ft Nomad trailer (1974 vintage) and I want to know if I can seperate the two axles, I want to make a CabinCar.
The frame would be 67 inch to the outside of the frame, 76 inches to center of tire (hubface). Can I use the springs or are tandum springs not applicable to mount stright to the frame shackle when used as a single axle spring. The old trailer was weight at 4400 lbs.
GaryW
I gots Cabin Fever :thumbsup:
more....
axle drop = look like 4in. overspring mounted
springs = three (3) leaf
length = 25 in. bolt hole to bolt hole
rear hub-hub 76 1/4
hubface-hubface 84
outside frame 67 1/2
inside " " 63 1/2
brakes = electric
tires P205/75R15
If I extend the plans 40 in, can I just move the axle 40in forward.
I was going to use 3x2 1/8th in channel for the frame.
GaryW
Postby synaps3 » Sat Feb 06, 2010 12:32 pm
Rip those hubs open, repack the bearings, and use the two best hubs on the axle that's in the best shape.
You should get new springs -- your trailer will be BOUNCY with that high of capacity springs under it.
-- Dave
Build log: here
synaps3
Images: 254
Postby angib » Sun Feb 07, 2010 11:03 am
Some of that could work, though there's a few issues.
I don't see a problem with the springs - half the previous 4400lb weight will get you somewhere near a big CabinCar weight.
You will need new spring mounts to replace the end that (I presume) is currently attached to an equalizer, but everything else should work OK.
The width of the axle means that you would have to make a very wide body, around 96", if you want to keep the wheels inside the body like on a CabinCar. So that's a pretty big jump up from the 78" or so of an original CabinCar.
One thing that probably won't work out right is the ride height, even if your axles have a 4" drop. The CabinCar needs something like 14" deck height to the top of the frame - I doubt very much that your old frame will be anywhere near that. This means you couldn't have the low-riding stance of the original CabinCar, but then maybe you're not looking for that.
The part about the 40" extension I don't understand. The wheels on a CabinCar are a loong way back so that the bed can be in front of (not on top of) them. This means that the hitch carries a lot of the trailer weight - nearly 25% - so it needs a big truck to be happy with this sort of hitch weight. I can't believe you want to increase that length by another 40", so I don't think I've understood what you plan for length.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby GaryW » Sat Mar 27, 2010 1:27 pm
I posted some photos, I starting on the frame:
http://my.att.net/p/s/community.dll?ep= ... thumbs&ck=
Cabin Fever :)
GaryW
Here's my plan for a Cabin Car.
Postby GaryW » Sat Mar 27, 2010 8:41 pm
4 Grand and others
Overall length 192"
Body length 144"
Center of wheel from rear 33"
15" wheels
Tounge length 48"
tounge weight 200 lb
Total weight 2000 lb
main frame width 55"
overall body width 79"
body height 71"
What ye say to this
ya or na ? :worship:
GaryW
Postby GaryW » Thu Apr 01, 2010 10:13 am
Started Frame construction
move to:
http://tnttt.com/viewto ... highlight=
:o
GaryW
