First Build
First Build
Postby Jaytak5 » Sun Jan 24, 2016 12:06 pm
So i started my first build in mid December and am making great progress and alot of that is due to this forum. Thanks guys!!! Here is what i have so far
The floor is 3/4in ply with a 2x3 frame and is insulated.
Image[/IMG]
I used roofing tar to weather proof the bottom.
Walls are made of the same ply and i used some scrapwood i had to frame
Got the walls up and decided to reward myself with a drink
This was my first attempt at skinning the front. I learned and tore it off and put up a better sheet.
Since all the walls are up i cut and fit all the insulation.
Got some batteries from and friend they are all 8.5ah and there are actually more to come. I wired them all in parallel to get more run time on everything.
Started putting up the walls near the gallry so i can build the galley.
Now electrical is going in! Im using computer fans because i live in san diego and the temperature doesnt really get unbearable here so i figure it would work. And thats when i am now. I'll update as i progress.
Jaytak5
Re: First Build
Postby Vedette » Sun Jan 24, 2016 12:47 pm
Great progress! :thumbsup:
Keep up the good work, and thanks for the pictures. :pictures:
Welcome to the Forum.
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
Re: First Build
Postby AZ_Desert_Rat » Tue Jan 26, 2016 1:34 pm
Welcome to the Forum Jaytak5... :applause:
You are off to a great start and what a bank of batteries... :shock:
The last time I looked into this many batteries was when I considered building an electric car... Did I count 10 batteries; what do these weigh apiece?? Out of curiosity, have you calculated the battery and trailer GVWR ?? I can only assume you plan on doing a lot of dry camping and running Microwave, A/C, etc.
I have a 19 foot FunFinder with 2 Grp 31 Deep cycle batteries that handle about everything I need for at least several days dry camping; I also have a 6x10 Cargo conversion that has a single Grp 27 Deep cycle and has seen up to 5 days dry camping... Wow a bank of 10 in a TD... :twisted:
Good luck with your build and keep the pics coming...
Happy Camping & Building,
John (JC)
The Arizona Desert Rat 6x10' Cargo Conversion
The FunFinder a 19' Toy Hauler
An AZ Desert Transplant
Gallery: gallery/album.php?album_id=3168
AZ_Desert_Rat
Images: 55
Re: First Build
Postby noseoil » Tue Jan 26, 2016 10:54 pm
Looks like a good build. Nice to see cherry for your wood!
137905
noseoil
Images: 670
Re: First Build
Postby Graniterich » Tue Jan 26, 2016 10:58 pm
Those appear to be small 7 ah batteries, only weigh a couple of pounds each. Used for ups or alarm systems. I have used one for drops that just have led lights.
Graniterich
Re: First Build
Postby AZ_Desert_Rat » Wed Jan 27, 2016 7:23 pm
Graniterich wrote:Those appear to be small 7 ah batteries, only weigh a couple of pounds each. Used for ups or alarm systems. I have used one for drops that just have led lights.
Thanks for the explanation Graniterich... I was not familiar with these... :oops:
That makes a huge difference from what I was thinking :thumbsup:
John (JC)
AZ_Desert_Rat
Images: 55
Re: First Build
Postby lrrowe » Wed Jan 27, 2016 9:02 pm
They are not that big or heavy. These look like the ones I use on my kayak for my fish finder.
Bob
lrrowe
Images: 439
