The floor is 3/4in ply with a 2x3 frame and is insulated.
I used roofing tar to weather proof the bottom.
Walls are made of the same ply and i used some scrapwood i had to frame
Got the walls up and decided to reward myself with a drink
This was my first attempt at skinning the front. I learned and tore it off and put up a better sheet.
Since all the walls are up i cut and fit all the insulation.
Got some batteries from and friend they are all 8.5ah and there are actually more to come. I wired them all in parallel to get more run time on everything.
Started putting up the walls near the gallry so i can build the galley.
Now electrical is going in! Im using computer fans because i live in san diego and the temperature doesnt really get unbearable here so i figure it would work. And thats when i am now. I'll update as i progress.
