Another golden oldie...It is ALIIIIVE
Postby teardrop_focus » Sat Dec 18, 2010 3:10 pm
Flippin' AMAZING. Looks lovely! What a beautiful-looking appliance.
:applause:
teardrop_focus
Images: 127
Postby Wolfgang92025 » Sat Dec 18, 2010 3:28 pm
WOW Doug :applause: :applause:
Another stove to add to the "Doug Hodder Vintage Camping Equipment Museum"
Hope to see it in person some day.....
Wolfgang
Wolfgang92025
Images: 660
Postby High Desert » Sat Dec 18, 2010 5:12 pm
Another beauty job Doug! You really did justice to another classic :thumbsup:
So, got any closeups of the new tank decal? Scott & Jeremy are really getting good at those.
Shaun
High Desert
Images: 27
Postby madjack » Sat Dec 18, 2010 5:31 pm
Dang Doug...that looks like it just came off the factory line...if it even looked that good then............
:thumbsup: :thumbsup: :applause: :applause: :applause: :applause:
Postby doug hodder » Sat Dec 18, 2010 5:54 pm
Thanks all...these are really fun rewarding projects and I just gotta keep busy in the garage if I'm not building a trailer. Next project the pre-way I got from Woodbutcher. Doug
Postby Kevin A » Sat Dec 18, 2010 5:58 pm
Another AWESOME stove by Dougcraft..... :thumbsup: :applause:
Doug, I tried to get that tank off today but the line at the PO was out the door and around the corner. I'll try again at a smaller, less busy PO that's open Monday.
Kevin A
The other guy
Images: 289
Postby doug hodder » Sat Dec 18, 2010 8:02 pm
Hang onto it Kevin....I think I'm OK...I patched it with JB weld...mooshed a load of it into the tank through a drilled out hole then held the tank so that it would flow into that rusted area on the inside of the tank and thumped it on the end with a rubber mallet to get it to flow. Smeared a patch on the outside.
Tested it with some air and in a tank of water...held fine. Painted it up, fueled it, put like 80 pumps to it and no leaks, stove fired right up. It's sitting in the garage with full pressure and fuel in it now. See what happens over night. JB weld seems to be like a really thick POR 15 to me. I've used it on the inside of fuel tanks before and had no problems with it. Doug
Postby doug hodder » Sun Jan 02, 2011 6:23 pm
I built a fire in it today...after some fiddling around with it...couldn't figure out why it wouldn't light...I found that the spring on the aux burner has lost some of its tension and the burner was wide open as well as the main. I need to take care of that little issue....and after clowning around with the preheat valve....I breathed some life into it. This baby really puts out some BTU's. I need to watch it as the flame is so hot and the walls are close to the burners, that I don't scorch it.
It needs a lead gasket for the fuel tank filler...need to come up with something for that. At least I got it running which is the main goal. It doesn't matter how good looking the stove is if it don't run! Doug
Postby starleen2 » Sun Jan 02, 2011 6:25 pm
NICE SAVE :thumbsup: Doug
starleen2
5th Teardrop Club
Postby Zollinger » Sun Jan 02, 2011 6:30 pm
WOW! Looks like it burns clean. Nice blue flame. You sure do good work Doug. Is their anything that you can't do?
Dawn
Green Lantern Corpswoman
Zollinger
Images: 64
stove
Postby mvperini » Sun Jan 02, 2011 7:26 pm
looking good Doug :)
Mike
1947 Kenskill teardrop kamper 4X10>
1951 Boles Areo 16ft Canned Ham>
1956 Roadmaster 20ft> Restored
1959 airstream 18ft restoration complete
1953 Pontiac house car
mvperini
Postby Wolffarmer » Sun Jan 02, 2011 7:45 pm
Pretty blue flames.
You making a commercial?
:lol: :lol:
Randy
Wolffarmer
Images: 309
Postby teardrop_focus » Sun Jan 02, 2011 9:24 pm
:applause: :thumbsup:
teardrop_focus
Images: 127
Postby S. Heisley » Sun Jan 02, 2011 10:11 pm
Doug, that is awesome! :o
Postby doug hodder » Sun Jan 02, 2011 10:47 pm
Zollinger wrote: Is their anything that you can't do?
Yup....keep a clean organized shop and house, oh yeah...and a woman! Doug
