by doug hodder » Sat Dec 18, 2010 8:02 pm
Hang onto it Kevin....I think I'm OK...I patched it with JB weld...mooshed a load of it into the tank through a drilled out hole then held the tank so that it would flow into that rusted area on the inside of the tank and thumped it on the end with a rubber mallet to get it to flow. Smeared a patch on the outside.
Tested it with some air and in a tank of water...held fine. Painted it up, fueled it, put like 80 pumps to it and no leaks, stove fired right up. It's sitting in the garage with full pressure and fuel in it now. See what happens over night. JB weld seems to be like a really thick POR 15 to me. I've used it on the inside of fuel tanks before and had no problems with it. Doug
