The LT... Thomas' Luxury Tent
Postby 2bits » Thu Sep 11, 2008 10:18 pm
Used the roto zip to trim the sides, that is a neat tool, not as bulky as a router. I didn't have a laminate trim bit and I wasn't going to be stopped so I just used a 1/2" roundover with a roller on it and just sunk it enough to keep the vertical cutting edge showing. Worked great.
Installed the lower front spar to put a cap on the end of the roof. I just glued and clamped it. Once it dries, I will tweak the position and glue and screw it to the sides. Those clamps hurt when they pop off and fly in your face while you are laying down too! haha :BE
Thomas
2bits
2bit Member
Postby john » Sat Sep 13, 2008 9:53 pm
I see that you had the foresight I lacked to cut a notch in each of the sides for the hatch. :applause:
I got around the problem by putting two layers of 1/4" masonite on the top. :roll: :roll:
heavy :(
Thanks for the close up pics of the roll under. I had a hard time visualizing that and avoided it. It looks too nice to avoid on my second build and I will do a cut and paste of yours. ok?
Build I -- Scenic ---
http://www.flickr.com/photos/8121727@N04/
Goto the Tear Build file
Build II -- Scenic II ---
viewtopic.php?t=29603
Build III -- Scenic Solo---
viewtopic.php?f=50&t=50324
Travel Blog----Now without Political Commentary
http://polifrogblog.blogspot.com/2009/0 ... -2009.html
The Constitution was ratified, not an interpretation thereof...
Penomeli ikibobo
john
john
Images: 261
Postby 2bits » Sat Sep 13, 2008 10:14 pm
john wrote:I see that you had the foresight I lacked to cut a notch in each of the sides for the hatch. :applause:
heavy :(
Thanks John! I am glad I could help you as much as you have helped me! You can thank Mike for his Benroy plans for that one! 'You could have notched after the walls were up, but it would be alot more work!
The front roll under was a big unknown for me too. all the way up until right when I did it! I know it needed to rol under but I didn't know where it would land, but I did know I didn't want to mess with notching it out for the trailer tongue, so I decided to lay it in place and cut it to where it stopped right when it touched the tongue. I then realized that I could glue the whole thing in place and then put that last spar in because I could just let the end of the roof dictate where to put it. It worked out well, I just need to seal the heck of the underside with roof tar, and I will feel very good about it.
Thomas
2bits
2bit Member
Postby 2bits » Sun Sep 21, 2008 11:59 pm
Things have been slow, helping other friends with alot of stuff and working alot of OT, but it's all good.
I put two coats of CPES epoxy on the entire roof using a paint roller and when it dried enough, I put epoxy filler over all the screw holes, roof edges, and joints. Need to put 2-4 more coats of roller epoxy on the roof for me to feel comfortable, and then it will be aluminum time! On another note, while I was helping my sister move Saturday, I discovered a deep cycle marine battery in a battery box, that she let me have, so I might be 12V independent sooner than I thought!
Thomas
2bits
2bit Member
Postby Mary K » Mon Sep 22, 2008 12:21 am
Wow, That's looking great!! :applause: Not too long and you will be camping!
Look, I can see the reflection of the hatch in the side of your TD. :)
Mk
BTW, I purchased a Roto Zip "After" I built my TD. I borrowed a router to build, but I couldn't resist the Roto Zip on sale. Now I have to find a project to use it on. :D
Mary K
Mary K
6000 Club
6000 Club
Images: 44
Postby 2bits » Mon Sep 22, 2008 12:30 am
Mary K wrote:Look, I can see the reflection of the hatch in the side of your TD. :)
WOW! You are very observant! I saw that too, and thought about editing my post to mention that but I thought it was too silly haha I HOPE I HOPE I HOPE to be camping soon! ! !
I LOVE the ROTOZIP !
Thomas
2bits
2bit Member
Postby 2bits » Mon Sep 29, 2008 8:39 pm
I got my second order of CPES in today, so I will put on my final two coats on the masonite roof, and I found a local RV shop I want to see what kind of edge trim and counter top edge they have available on Wednesday. I am thinking I need to go with dead Soft with the curves of my profile.
Work will progress slowly for the next week or two, I found a new engine for my truck that I will be testing, cleaning and installing so I have to shift gears for a little bit and focus on the tow vehicle for a while. :vroom: I still check the board almost every day though!
Thomas
2bits
2bit Member
Postby peggyearlchris » Mon Sep 29, 2008 8:56 pm
Thomas, It's looking great. Keep up the good work. Hope to see it someday. :thumbsup: :thumbsup: Peg
peggyearlchris
Images: 56
Postby looped » Tue Sep 30, 2008 5:00 am
2bits wrote:I got my second order of CPES in today, so I will put on my final two coats on the masonite roof, and I found a local RV shop I want to see what kind of edge trim and counter top edge they have available on Wednesday. I am thinking I need to go with dead Soft with the curves of my profile.
Thomas,, after not finding any at united rv in haltom city ( told to be the only place in tarrant county that would carry it) i am at a loss as where to find it. post here or shoot me a line with the info of where to find it locally. i will be trying a rv parts yard in mansfield this week to see what i can find. if i cannot find any well theres always the blowtorch :)
"face it man. It's just not possible to fry an egg with a bicycle powered hairdryer!"
- Dave Lister
looped
Images: 31
Postby Cliffmeister2000 » Tue Sep 30, 2008 9:08 am
Is it CPES you are looking for? If so, the Rot Doctor sells it via mail. Don't know of any other source.
http://www.rotdoctor.com/products/product.html
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
My Teardrop build pictures
Cliffmeister2000
Titanium Donating Member
Images: 157
Postby looped » Tue Sep 30, 2008 5:43 pm
Sorry i should have been more clear on that,, i was speaking of the dead soft aluminum edging.
- Dave Lister
looped
Images: 31
Postby 01Sport » Tue Sep 30, 2008 6:00 pm
Looking good :thumbsup:
I have a question. I asked it on another thread but no one answered it. I am covering my whole td in aluminum. Do I still need to seal it with something like CPES?
K.C.
Teardrop Name: Golden State Teardrop
01Sport
Images: 29
Postby Cliffmeister2000 » Tue Sep 30, 2008 7:16 pm
If you coat the wooden structure with CPES, you are insuring against damage in case of leaks. If you think you will be leak free, you don't need CPES. I'm not that good, so I would use it.
God Bless
Cliff
♥God. ♥People.
1 John 4:9-11
Cliffmeister2000
Images: 157
Postby asianflava » Tue Sep 30, 2008 7:42 pm
01Sport wrote:Looking good :thumbsup:
I put 2 coats of epoxy on mine. I was concerned about condensation forming between the aluminum and the wood. It doesn't matter what it looks like, you are covering it with aluminum. Did I need it? I don't know. Besides, it's cheap insurance (well, relatively cheap).
asianflava
Postby 01Sport » Wed Oct 01, 2008 2:11 am
Thanks you both for your replies. Something to think about.
K.C.
01Sport
Images: 29
