Ned's Grumman 2 (ish) TD in New Zealand
Re: Ned's Grumman 2 (ish) TD in New Zealand
Postby dales133 » Tue Feb 03, 2015 3:32 pm
Good stuff
dales133
Postby Ned » Wed Feb 04, 2015 1:44 pm
Bought myself a brad nailer and went to work making some drawers for the TD
putting some more cabinets together tonight :)
think i need a regulator for my compressor so i can dial the pressure down for the brad nailer, as i'm blowing right through the 3mm ply...
Build Journal :: My Grumman 2 (ish) TD
Ned
Postby Sheddie » Wed Feb 04, 2015 1:56 pm
It's amazing how quickly things start to take shape. Keep up the momentum :thumbsup:
yes you do need a regulator, most of those things run at 90 psi.
We are heading through Auckland with TD today :D
Sheddie
Images: 1129
Postby Ned » Wed Feb 04, 2015 1:58 pm
if i didnt work on K Road, i'd ask you to stop in, but that would sure be a nightmare haha. I'll keep my eye on the motorway and see if i can spot it :) my office overlooks spaghetti junction
Ned
Postby Sheddie » Wed Feb 04, 2015 2:28 pm
We will txt as we are coming over the harbour bridge, you can keep an eye out. Towing with the red Capri.
Sheddie
Images: 1129
Postby Ned » Wed Feb 04, 2015 2:35 pm
Going south right? after the bridge, once you go through the under bridges at spaghetti, you should see a big rusty building to the left, the ironbank building. I'll be looking from the top floor, middle office of 3 :) looking forward to it haha!
and my PCBs turned up for the light controller. Basically just an 8 channel dimmer for LED lights but will also allow me to remote control it from a key fob, or even my phone. Will make it just a 'dumb' switch for now, but can upgrade the code later to do cool things like phone control :)
Ned
Postby Sheddie » Wed Feb 04, 2015 7:39 pm
We will keep an eye out. Leaving Albany shortly :D
Sheddie
Images: 1129
Postby Ned » Wed Feb 04, 2015 8:05 pm
Also got aluminium delivered at lunch :D
Ned
Postby felixx » Thu Feb 05, 2015 2:47 am
WOW Ned
You dont mess about
felixx
Images: 22
Postby Ned » Thu Feb 05, 2015 5:13 pm
I try not to. It needs to be done in a few weeks!
Ned
Postby Ned » Sun Feb 08, 2015 3:51 pm
didnt get as much done as i wanted unfortunately :( everything just takes longer than expected...
made the floor and mounted it. It over hangs the trailer by 5mm each side, and the walls have slots routed in them for the floor overhang to give it some more strength by adding glue and pocket screws galore.
Here the walls are mocked up
Also managed to prepare a lot of the galley panels, so cut holes in them and cut some insulation. Made a make shift hot wire cutter with a car charger and some nichrome wire which works ok. Need to use my lab power supply instead as the car charger doesnt have enough volts to get the wire hot enough for big spans.
Glued some of the inner walls on, and should be good to mount the walls next weekend, and build the cabinets, ready for the outer walls and ceiling! and then the end will be in sight! (maybe)
Ned
Postby dales133 » Sun Feb 08, 2015 4:03 pm
Looking good ned making us all look bad!
dales133
Postby Ned » Mon Feb 09, 2015 3:16 pm
Cut out some foam yesterday. Fixed the silly cutter i made by adding a spring, as the nichrome wire stretches HEAPS when it got hot.
Clamped it to the side of the trailer to get it 15mm above the top of the trailer so i could feed the 30mm foam through to get 15mm pieces to fit in the 17mm wall. Figured that will be sufficient...
Ned
Postby Ned » Tue Feb 17, 2015 2:42 pm
did this on the weekend
and also did some cabinets in the galley (i'm a TERRIBLE cabinet maker, so i'll make sure i wont glue anything in so i can replace it after my holiday in 2 weeks )
Setup a little 'jig' to cut my roof sheets down to the right width for the teardrop
and another quick shot of what it looked like last night
and some eggs i had for breakfast this morning just because i can :P
Ned
Postby Sheddie » Wed Feb 18, 2015 2:47 am
Jeez Ned you're really humming along!!!! Keep up the momentum, you are doing well.
Sheddie
Images: 1129
