didnt get as much done as i wanted unfortunately
everything just takes longer than expected...
made the floor and mounted it. It over hangs the trailer by 5mm each side, and the walls have slots routed in them for the floor overhang to give it some more strength by adding glue and pocket screws galore.
Here the walls are mocked up
Also managed to prepare a lot of the galley panels, so cut holes in them and cut some insulation. Made a make shift hot wire cutter with a car charger and some nichrome wire which works ok. Need to use my lab power supply instead as the car charger doesnt have enough volts to get the wire hot enough for big spans.
Glued some of the inner walls on, and should be good to mount the walls next weekend, and build the cabinets, ready for the outer walls and ceiling! and then the end will be in sight! (maybe)
