"Pork Chop Express"
Re: "Pork Chop Express"
Postby KCStudly » Wed Feb 19, 2014 4:50 pm
Looks good! :thumbsup:
Postby SLUG36 » Mon Mar 03, 2014 7:45 am
KCStudly wrote:Looks good! :thumbsup:
thanks, progress has been slow. I was reprimanded for spending to much time working on the camper. The only thing accomplished in the past 2 weeks were me cleaning, organizing and vacuuming the inside. and a coat of stain on the interior shelf that housed the fridge(only because the wife was at work yesterday). :lol:
Making big pieces of wood into the wrong size..... for over 30 years....
SLUG36
Images: 137
Postby KCStudly » Mon Mar 03, 2014 9:06 am
They can become a bit of a mistress, can't they? ;)
Postby SLUG36 » Wed Mar 05, 2014 7:38 am
KCStudly wrote:They can become a bit of a mistress, can't they? ;)
yeah, and since the camper isn't finished, and it's cold outside. I figured it would be wise to heed her warning. I would hate to have to sleep in there right now. then I would have to change the name to "THE DOG HOUSE" :rofl2:
SLUG36
Images: 137
Postby SLUG36 » Mon Mar 10, 2014 7:07 am
a little progress this weekend. I have 5 of the 6~ 3/4" white LED lights installed and wired in the cabin. and I have filler applied to the inside corners of the ceiling joints. but, it was humid as heck and cool this weekend, and the filler (water based) did not want to dry. I also had a couple of people that were driving by the house stop and talk with me about the camper and asked if it was ok to check it out. and Thursday, we had a false alarm on a house fire (dryer vent producing steam), and the Fire Department was checking the camper out.
SLUG36
Images: 137
Postby SLUG36 » Sun Mar 23, 2014 1:04 pm
I haven't been posting to much lately. I have been working on filling the corners of the ceiling, and with the high humidity and cooler temperatures. it has been taking a long time for the water based filler to set up. here are some pics of the front area with one coat of primer. and you can see I still have some pin holes to fill. I had bought a cheapo plastic 1" putty knife and rounded the end to help give me a radius in the corners. And I have all 6 of the LED lights installed. it should give a decent amount of light and I am going to have a a larger 72 led light for brighter light.
118171118172
SLUG36
Images: 137
Postby SLUG36 » Sun Mar 30, 2014 7:02 pm
not much noticeable progress but i did manage to build a jig, to build a jig to cut the interior port hole windows out.
118446118447
SLUG36
Images: 137
Postby SLUG36 » Tue Apr 01, 2014 6:47 am
the plan for the windows is as follows. I am going to use some 12"x12"x1/4" square lexan and sandwich between the the outside skin and the interior skin using trim rings and some butyl sealant. I am hoping to have the Lexan ordered by friday.
SLUG36
Images: 137
Postby SLUG36 » Mon Apr 14, 2014 6:26 am
after a test "cut out" of the rear windows with 2~ 12" diameter windows, I decided it would look much better with one larger 12"x 33" oval port hole style window. and with the rear wall being 1 1/2' framing, I was able to use 2 layers of 5/8" ply wood to achieve a 1 1/4" space to press the 1/4" Lexan window to the outer skin. hopefully this weekend I will be able to buy some 1/4" ply and start skinning the roof. and rear outer wall. and just to make things move backwards. I am going to reshape the front outer wall to add a little more style.
119033
SLUG36
Images: 137
Postby SLUG36 » Thu Apr 17, 2014 10:42 am
Major score, I was cruzing the local online classifieds yesterday and lowe and behold....
a 3 way fridge for $145....heck yeah.119172119171
now I need to find the specs for side clearances for installation.
SLUG36
Images: 137
Postby SLUG36 » Thu Apr 17, 2014 10:22 pm
well, it turns out it is only a 2 way fridge. but it is still better than just a 120v unit
http://www.dometic.com/enus/Americas/USA/RV-Products/refrigerators/Refrigerator-Product-Display/?productdataid=71803
SLUG36
Images: 137
Postby SLUG36 » Fri Apr 18, 2014 7:55 pm
after running around all day, I decided to cut out the rear window opening on the outer skin. had the rear skin temporarily installed and a pilot hole to use my flush cut router bit to zip around the window cut out. after smelling the router fry, I took the 2 year old router apart, and it was fried. off to the pawn shop and found a older "Made in USA" Craftsman router for $30. and zipped the window opening out.
119197
I also started on the roof skin and the dreaded rear upper corner radius. I think I have them sorted out and will share pics later.
I also have the 58 Chevy Biscayne tail light housings mocked up and would love some input on the placement.
SLUG36
Images: 137
Postby SLUG36 » Sat Apr 19, 2014 8:39 pm
rear corner radius which i am going to cover with fiber glass along with the side radius,roof, front and rear panels and paint.
119268
SLUG36
Images: 137
Postby SLUG36 » Thu Apr 24, 2014 7:32 am
a little bit of work done this week, after working 10 hour days and a 1.5 hour drive home. I try and not fire up any power tools after it gets dark, but, I'm sure my neighbors hate me on the week ends when the table saw cranks up at 7:30 am.
119407
sorry about the nasty pic.
SLUG36
Images: 137
Postby SLUG36 » Thu Apr 24, 2014 9:27 pm
more progress
119419119418
SLUG36
Images: 137
Users browsing this forum: Bing [Bot] and 18 guests
