If you’re making a trailer that is mostly mattress on the floor , then you need even less eh ?
by GPW » Mon Apr 21, 2014 4:56 am
Actually we’ve needed an Engineer here to Prove the concept .... mathematically ... All our work has been TLAR and much testing ... Welcome Aboard !!!!
TeriL wrote:Well, I never got my PE (Professional Engineer) certification so I can't legally practice engineering in most states or for that matter, even legally call myself an engineer!
Generally, I use TLAR for most things utilizing experience. Most of my design work was never stressed anywhere near breaking or the general practice was to grossly over build to account for unknown field usage. My first job was for a petro-chem plant design/construction company where we typically designed with massive safety margins. Our plants were known for not blowing up and customers usually ran them over design capacity knowing that.
Later, I worked in the semiconductor industry where precision was paramount so stiffness was the primary goal. When you design for stiffness, strength isn't an issue unless the materials are so grossly weak (like never at work). Drywall is my favorite example of a relatively stiff construction material but the core material is so weak that it would break from it's own weight without the paper faces making a composite sandwich.
-- Teri
-- Teri
