Ultralight Floor
Re: Ultralight Floor
Postby GPW » Mon Mar 24, 2014 6:13 am
You know you could get away with a Thin floor with a little “give” , especially if you were planning on using a rug or carpet floor covering and used some carpet padding under that ... That would absorb a lot of compression before it gets to the floor ... Of course that eliminates any Flamenco Dancing on it ... :roll:
If you’re making a trailer that is mostly mattress on the floor , then you need even less eh ? :NC
Postby atahoekid » Thu Mar 27, 2014 2:31 pm
Yup, standing and dancing on the floor requires a lot more material (strength) be used in construction. Spreading the load by keeping your floor mostly covered with the mattress reduces the amount of strength needed in building the floor. (You also need to keep your 500# of ballast spread out) :beer: :beer:
Mel
atahoekid
Images: 158
Postby TeriL » Sun Apr 20, 2014 11:30 pm
Hi levsmith,
As a retired engineer, listen to angib on his discussion of sandwich construction. I was going to reply with essentially the same info but luckily I saw his post first. Saved me a lot typing :)
Years ago I made a sample piece of 3/4" XPS Styrofoam with a single layer of epoxy glass on both faces and I used it as an example to show others how stiff and strong it was. Unfortunately I lost it but more recently I needed a simple lap table for my computer and all I had available was a piece of Styrofoam and a roll of builders kraft paper. So I laminated some of the paper to the foam faces with carpenters glue and now have a very lightweight lap desk. As others have pointed out, it is the skin that provides most of the sandwich's rigidity and strength. Think drywall, the strength is in the paper faces, the gypsum core wouldn't be able to support itself without them.
If you want to mathematically convince yourself, the formula for calculating the moment of inertia of a rectangular solid beam is I = b h^3/12 where b = width and h = height. This calculation is used for computing among other things, the deflection of beams given various loadings.
For a sandwich construction with faces of the same thickness, just calculate the moment of inertia for each face with the height measured from the center of the sandwich. To save you from the math, it will nearly be the same as a SOLID pice but significantly lighter. However, to indemnify myself from a lawsuit and forum arguments, there are caveats. Specifically the foam must be stiff enough from crushing or excessive elastic compression and be strong enough in shear stress. In normal Foamie construction, those considerations don't come into play unless someone wishes to tap dance with stiletto high heels! For the trivia minded, the floors in airliners are sandwich construction but with a thicker top face so someone in stiletto high heels won't punch holes in the floor. I guess someone must have done that some time ago as I'm sure the male engineers at Boeing wouldn't have though of that. If they could, I'm sure the airlines would Ban stiletto high heels so they could save the extra weight of the thicker top face.
For your lightweight motorcycle trailer, I think a floor with some high quality 1/4" plywood faces over 1-1/2" XPS Styrofoam would be all you need. By high quality plywood, "Baltic Birch" would be my choice. Baltic birch ply is available down to 1/8th inch and even thinner. I've seen small pieces in hobby stores 1/16" thick. Epoxy would be the best glue but Titebond 3 wood glue should be enough and lot cheaper.
Hope I haven't bored everyone with my engineering lesson. Good riding with you favorite buddy. Be safe.
-- Teri
Our reach should exceed our grasp or what is a heaven for? -- Marshall McLuhan
TeriL
Postby GPW » Mon Apr 21, 2014 4:56 am
Actually we’ve needed an Engineer here to Prove the concept .... mathematically ... All our work has been TLAR and much testing ... Welcome Aboard !!!! 8)
Postby TeriL » Mon Apr 21, 2014 11:39 am
Well, I never got my PE (Professional Engineer) certification so I can't legally practice engineering in most states or for that matter, even legally call myself an engineer!
Generally, I use TLAR for most things utilizing experience. Most of my design work was never stressed anywhere near breaking or the general practice was to grossly over build to account for unknown field usage. My first job was for a petro-chem plant design/construction company where we typically designed with massive safety margins. Our plants were known for not blowing up and customers usually ran them over design capacity knowing that.
Later, I worked in the semiconductor industry where precision was paramount so stiffness was the primary goal. When you design for stiffness, strength isn't an issue unless the materials are so grossly weak (like never at work). Drywall is my favorite example of a relatively stiff construction material but the core material is so weak that it would break from it's own weight without the paper faces making a composite sandwich.
-- Teri
-- Teri
TeriL
Postby KCStudly » Mon Apr 21, 2014 8:32 pm
Oh Geep, have you forgotten all of my moment of inertia diatribes so soon? :R No worry. :lol:
Welcome aboard TeriL! :thumbsup:
Postby jae » Tue Apr 22, 2014 3:40 pm
TeriL wrote:Well, I never got my PE (Professional Engineer) certification so I can't legally practice engineering in most states or for that matter, even legally call myself an engineer!
-- Teri
-- Teri
Haha, same here, though my business card does say "Design Engineer". Haven't worked on stamped drawings in about 5 years. Started out doing pipe stress for refineries and it was kind of scary to do revamp work and start running calcs on existing equipment with current process parameters. Really speaks to the importance of those safety factors.
jae
Users browsing this forum: DrAlvarez, jgmahoney and 10 guests
