Pico Light Foam and fiberglass
Re: Pico Light Foam and fiberglass
Postby atahoekid » Fri Jun 01, 2012 10:15 am
That looks like it is coming along nicely. Too bad cold weather slows down the cure. I hate waiting for stuff to dry. Makes me crazy :? :x :? . I'm glad I decided not to glass my interior though, I can't imagine how messy that must be. You are a braver soul than I. I'm not looking forward to glassing my front curve on the outside when I get to that point. That has the potential to be one drippy, messy job. I guess it's an issue of getting the epoxy thick enough. Good idea on using the boards to hold the foam down. I'm worried about my foam panels trying to move or spring back when I assemble it so I will definitely be doing something similar. Great work. In spite of waiting for your epoxy, you're moving along at a pretty good clip. :thumbsup: :thumbsup:
Mel
atahoekid
Images: 158
Postby aksnowryder » Fri Jun 01, 2012 2:42 pm
Thanks Mel, it was messy but not to bad. I waited to bolt the body to the frame so I can turn it and keep it from dripping all over me.
Never give in--never, never, never, never, in nothing great or small, large or petty, never give in except to convictions of honour and good sense. Never yield to force; never yield to the apparently overwhelming might of the enemy.
Sir Winston Churchill- Speech 1941 Harrow School
aksnowryder
Images: 61
Postby aksnowryder » Sat Jun 02, 2012 3:08 pm
I brought the body into the house and placed a heater in the room and that did the trick of getting the interior roof to set up nice. posting.php?mode=reply&f=55&t=50313#
Next step was getting a layer of cloth and epoxy on the exterior of the roof. So... here are some pics. One more layer of cloth on the exterior, hopefully I'll get that done Sunday. Right now we are having some great weather, if it holds out should be great for the curing and I won't have to bring it in or heat it. Here is hoping!!! posting.php?mode=reply&f=55&t=50313#
93022 this pic is of the cloth being laid out and cut to fit and the relief cuts in the cloth so I can make the bends.
93023 Here is another view of the cloth laid out.
93024 Here is the cloth after the epoxy was applied. Second coat to come hopefully late tonight or tomorrow afternoon.
aksnowryder
Images: 61
Postby aksnowryder » Sat Jun 02, 2012 3:15 pm
Forgot to mention in that post, the screws and boards did a fair job of holding everything in place while working on the interior. What I did for the outside and to make sure the roof was as tight to the body as possible was to tie a heavy string around the outside edge of the roof and used tie-down ratchets to pull it very tight. I just epoxied over the top of the string and will cut off the ends once it is cured. Made for a very effective clamping system. posting.php?mode=reply&f=55&t=50313#http://www.tnttt.com/posting.php?mode=reply&f=55&t=50313# If you look close at the last pic you can see the string under the fiberglass at the edge of the roof line.
aksnowryder
Images: 61
Postby GPW » Sat Jun 02, 2012 4:22 pm
Wow!!! A No foam roof... :o First time for everything !!! 8)
Postby KCStudly » Sat Jun 02, 2012 8:19 pm
Did I miss something? Thought the roof was glass over foam.
Postby aksnowryder » Sat Jun 02, 2012 11:14 pm
The roof is glass over a honey comb material 1/2" thick with cotton backing on both sides. It is called, "Plasticore."
aksnowryder
Images: 61
Postby KCStudly » Sat Jun 02, 2012 11:19 pm
Ooo, I did miss something.
Cool. Build on! :thumbsup:
Postby wagondude » Sun Jun 03, 2012 8:39 am
KCStudly wrote:Ooo, I did miss something.
I missed it too. This one is moving at light speed. Hard to keep up.
Bill
Bill
101137
wagondude
Images: 35
Postby aksnowryder » Sun Jun 03, 2012 11:03 am
To be fair to everyone, I guess I never said I was making the roof out of the Plasticore. Sorry about the confusion. Very pleased with the strength of this thing, I put all of my weight on the rood last night 202lbs. and it didn't even bow. That is with only one coat of cloth and epoxy. I still have one more to go. The good weather is sure welcomed here as it sure speeds up the curing!
aksnowryder
Images: 61
Postby aggie79 » Sun Jun 03, 2012 11:23 am
Your teardrop is looking fantastic!
I don't want to redirect anyone from your wonderful build so perhaps could you in another thread tell us a little more about Plasticore? Is it flexible enough to bend, etc.
Postby eaglesdare » Sun Jun 03, 2012 2:42 pm
:thumbsup: :wine:
Louella
May the foam be with you.
eaglesdare
Postby aksnowryder » Mon Jun 04, 2012 1:44 am
Thanks everyone. I will get a pic of the Plasticore up for ya. Yes it is very flexible and easy to work with.
aksnowryder
Images: 61
Postby pete42 » Mon Jun 04, 2012 5:12 am
good job
working with fiberglass can be a mess or a joy
sounds like you have experienced both ways.
pete
pete42
Postby GPW » Mon Jun 04, 2012 7:25 am
Pray tell us more about this “Plasticore” ... Please !!! :thinking:
