Low Wider... Simple
Re: Low Wider... Simple
Postby atahoekid » Sat Aug 18, 2012 1:23 am
From my experience a 2" foam roof will sag a bit (about 1/4" in a 7 foot wide span) in the middle without some support. I used 1 x 3's laid flat about 18" apart for spars and bulkheads front and rear to provide roof support. Although I haven't walked on it, I have crawled a bit on it (just the edges) and it didn't collapse under my 200 plus pound body. Me crawling on all fours... hmmm glad someone didn't take :pictures: :pictures: :pictures: :o :shock:
Mel
atahoekid
Images: 158
Postby bonnie » Sat Aug 18, 2012 5:45 am
:D :D
Remember, the turtle won. :)
bonnie
Images: 107
Postby GPW » Sat Aug 18, 2012 6:10 am
Mel, I can see many good reasons for bracing the roof ... But since I’ll (theoretically) be using 3.5” thick foam , I don’t think there will be much sag after I skin both sides (schmaybe’ ? ) :roll: ... For a big flat box like the LW, I’m thinking about skinning the panels inside and out before attaching them ... so much easier to do for one person ... but then we’ll have to pre-round all the edges ... :thinking: Then all I have to add is the reinforcing strips , and I’m thinking about using that fiberglass tape like I did last time :o (it’s held up very well) And it’s easy ...
I had thought of hot wiring some slots in the foam as mentioned ^ and glue flush some ribs .. that seems like a good choice too, and a multitude of attachment places for miscellaneous items related to camping ... LED light fixtures,cargo nets, Lanterns, Christmas lights , incidental wiring ex post facto, etc. . ... So much thinking for such a simple box ... I find , the simpler you try to make it , the More thinking you have to do ... :thinking: Everything has to be accounted for during all phases of construction..
I think I’ve been reading too much " Studly Engineering " :lol: :lol: :lol:
Postby atahoekid » Sun Aug 19, 2012 10:14 pm
Good point about the thicker foam, it shouldn't sag if 2" barely sags.
That's the one disadvantage I've discovered while building the Road Foamie. You've got to preplan where you want to hang or run anything . If you're planning on hanging anything, you'd better know where cuz you're going to need to add a hardpoint or have some other underlying structure that you can screw into. If you're running electrical, you've got to know that before you skin over. Other than that, I love it...
Mel
atahoekid
Images: 158
Postby GPW » Mon Aug 20, 2012 5:14 am
It’s difficult to account for Everything that must be mounted ... True Dat ! But you can easily add a hard point later ... if needed ... just not as easy as one that’s planned for in advance ... All part of that pre thinking we must do ... ;)
Postby GPW » Mon Aug 20, 2012 8:02 am
Just more doodling’ ... this is how I do my “thinking” ... 97014
Postby Papi » Mon Aug 20, 2012 4:45 pm
:applause: I like where this is headed!
I dream of a day when a chicken can cross the road without having his motives questioned.
Papi
Images: 50
Postby GPW » Tue Aug 21, 2012 4:38 am
Thanks Papi , just trying to plan ahead ...
Postby aggie79 » Thu Aug 23, 2012 12:35 pm
Papi wrote::applause: I like where this is headed!
Me too! BTW, what do you plan to have in the wedge - storage?
I've been thinking of something like this plus a lifting roof like the BUB or a tilting roof like a Compact for some time. It's time to see some foam dust!
Take care,
Postby GPW » Thu Aug 23, 2012 1:32 pm
Tom , thinking the wedge would have a big divided shelf for storage (and the Cat) and below would be the slip in , slip out AC ... and a door/hatch for that ...
A foam roof with canvas like the Bub might be a lot Lighter , and just some simple old timer supports needed .. :thinking:
Postby GPW » Fri Aug 24, 2012 5:34 am
I might have screwed up ... :o Called the guy with the foam , left a message , answer came there none ... :roll: I hope he still has some foam left ... otherwise we might have to resort to Plan B , actually buying foam retail ... :frightened:
One of the rules of Salvage is : "If you see a good deal , jump on it , it won’t be there long" ..... I forgot about that .. :oops: :R
Postby GPW » Fri Aug 24, 2012 10:03 am
Called the gentleman back , he’s still got the Foam :thumbsup: but is moving it Monday because of the uncertainty of the approaching storm ... It would all just blow away :o ... Trying to get down there this weekend .... have to arrange some help ... Fortunate I didn’t miss this ... 8)
Postby eaglesdare » Fri Aug 24, 2012 11:55 am
go get that foam! :applause: :wine:
Louella
May the foam be with you.
eaglesdare
Postby GPW » Fri Aug 24, 2012 3:43 pm
A friend of mine is coming over tomorrow with his open back pickup truck (mine has a camper top) and we’re going get as much as we can :thumbsup:
Postby linuxmanxxx » Fri Aug 24, 2012 4:44 pm
The early bird gets the worm. .....the late bird gets the turd!
linuxmanxxx
Images: 10
