2 Person Standy Build
Re: 2 Person Standy Build
Postby Fyddler » Thu Mar 28, 2013 9:01 am
O2 was for cutting, AC arc welder for welds. I am lucky enough to have an Uncle who welded on the shipyard. I can run a bead, but it's not pretty! This will definitely be overbuilt material wise, but I already had the trailer with a title.
To err is human, to really foul up requires a computer
Build Log: http://www.tnttt.com/viewtopic.php?f=50&t=55017
Fyddler
Postby Fyddler » Thu Mar 28, 2013 9:39 am
My $10.00 garage sale windows. There 24" long. Proves my #1 rule in bargaining, never ever throw out the first offer! I was ready to hand him $40 cash!
Fyddler
Postby laroosta » Thu Mar 28, 2013 10:33 am
Nice find !!! :thumbsup: I looked at windows yesterday online.........pretty pricey :o
laroosta
Images: 36
Postby KCStudly » Thu Mar 28, 2013 2:47 pm
Fyddler wrote:O2 was for cutting, AC arc welder for welds.
Oh, I was confused. I thought you said you needed O2 to weld. You must have some more cutting to do.
Build on.
Postby Fyddler » Sat Mar 30, 2013 3:37 pm
$3.00 garage sale find!
Fyddler
Postby CarlLaFong » Sat Mar 30, 2013 4:38 pm
That's actually a sunroof. I had an identical one in my old 72 Datsun PU
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Postby Fyddler » Sat Mar 30, 2013 5:14 pm
Yup. New in box. Figured it would look great in the front
Fyddler
Postby KCStudly » Sat Mar 30, 2013 10:58 pm
Score!!! :thumbsup:
Postby Fyddler » Sun Apr 07, 2013 1:08 am
As I am getting closer to having a trailer frame I am starting to think about the build. I am going with 3/4" solid plywood walls, 3/4" floor. I see a lot of people putting in a sub floor under the plywood. Is there a reason to not just bolt the 3/4" plywood frame right to the trailer frame?
Fyddler
Postby KCStudly » Sun Apr 07, 2013 2:44 am
From what I have read, unless you intend to insulate your floor (...and there are plenty of good reasons to do that) there usually is no need to build a subfloor.
If your trailer width and floor width are reasonably close (say within a foot... 6 inches on a side), and you do not have to build up over the fenders in order to create a flat floor, then the extra wood is not necessary.
This, of course, is just the opinion that I have developed from reading the numerous posts on this subject. My TD is being built completely differently. :D
You may want to search and or read more about this topic before you make your final decision. :thumbsup:
Postby Corwin C » Mon Apr 08, 2013 10:20 pm
Fyddler wrote:As I am getting closer to having a trailer frame I am starting to think about the build. I am going with 3/4" solid plywood walls, 3/4" floor. I see a lot of people putting in a sub floor under the plywood. Is there a reason to not just bolt the 3/4" plywood frame right to the trailer frame?
My plan is to bolt the floor directly to the frame and insulate between the frame members. I feel that the floor framing that most people seem to do is a little redundant.
Corwin
Image Image Image
-- myself
Corwin C
Images: 78
Postby rmef27 » Tue Apr 09, 2013 1:49 am
I want to build something like what you are building so I will definitely be paying close attention to your build.
rmef27
Postby Fyddler » Sat Apr 13, 2013 12:32 am
Finished getting my trailer frame welded up and a coat of primer today. My goal is to get the floor built by the end of the weekend.
Fyddler
Postby Fyddler » Sat Apr 13, 2013 6:08 pm
Built the sub floor today and worked in the design a bit. Hadn't planned on doing a sub floor but didn't take into consideration for the tongue reinforcements so decided that in order to get the floor drop I wanted in the entrance I needed the extra clearance. Making sawdust makes me HAPPY HAPPY HAPPY! I also realized that my current sidewall design won't hide my frame so back to the (sketchup) drawing board for some revisions.
Fyddler
Postby George Taylor » Sat Apr 13, 2013 7:26 pm
I ran into a similar; issue when I was building our first camper. Ours is 10 ft long and 4 ft tall. I used 5/8 ply for the main structure and used the scrap to fur out the inside. I also used a 6 inch wide piece to joint the pieces together. I used construction adhesive and screws to hold it all together. I then installed 1/2 inch foam in between the during strips before I installed the 1/4 inch birch ply. I was able to hide all of the wires in the walls as well. Walls are strong and the camper stays realty warm in the cold. I will recommend using pt ply for the floor.
George Taylor
