Stainless Steel Micro-Airstream behind motorcycle
Re: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Mon Mar 18, 2013 3:58 am
harleykamper wrote:Man! That's coming along great! Very sweet build. It should be very light and solid to boot! Keep up the good work. :applause:
Any Idea or estimates of the finished weight?
Thanks ladies & gentlemen !
My plan is to finish without slideout between 120 and 130 kg (265 to 285 lb) !
The slideout is only an option for later, because I do not need it travelling alone, but it's part of the concept.
50 years camper and 35 years biker !
1977 Eriba Troll
2001 Honda GL1800 with trailer hitch, Ford Focus Pininfarina Convertible with hitch
ST1100
Images: 199
Postby oicu812 » Tue Mar 19, 2013 2:51 pm
Great looking build. Your moving right along. How thick is your stainless and what series? I think you said .6mm [26 gage US ] is that what you bought?
The pic with the Drill motor and rivet gun, looks like a AEG and a Gesipa, if so I have the same ones. Bought both in the mid 80's and still work fine. Good tools.
Pie are square?
oicu812
Postby ST1100 » Tue Mar 19, 2013 5:40 pm
the stainless is 1.4301(AISI 304) and is 0.6mm thick.
the Suki riveting tool is 25 years old and similar to the gesipa.
The drill motor, I confess, is a 9.99 Euro motor of the no make "budget" I bought at a 20% off action for 7.99 Euro (new!).
I needed a new accumulator for my battery screwdriver and the drill plus a long cable was cheaper and more powerful !
I think I have it 13 years now !
But normally I prefer quality tools !
My big drill motor is a Bosch and I own it 22 years now. Need only new brushes every 15 years :-)
Only if I need a tool only once, I try a cheaper one.
But better take the box with the "5 years warranty" sticker and keep the receipt :)
1977 Eriba Troll
ST1100
Images: 199
33: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sat Mar 23, 2013 12:09 pm
Yesterday I got the bottom of my box !
Clecoed it today underneath my alu bars.
The left will become my baggage compartment, the bigger right will get a well to step in, that I can pull up during towing.
1977 Eriba Troll
ST1100
Images: 199
34: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Sun Mar 24, 2013 8:51 am
Drilled and deburred today all the holes for the connection between frame and deck ...
... and glued the deck with polyurethane Sikaflex 221 onto the frame and set all the rivets.
1977 Eriba Troll
ST1100
Images: 199
35: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Mon Apr 01, 2013 4:19 pm
Long weekend and the polyurethan glue had time to harden last week !
I had to take away the front and rear bar because I forgot to seal between frame and bars with PU.
Glueed the bars now with PU to the frame and riveted all together again.
While the PU had time to harden, I built the lid for my baggage compartment.
It has to be solid, because I will sit and sleep on it later.
then riveted it with piano hinge to my frame.
Today I built the small wall, upon which the baggage door will rest and the support angles left and right.
1977 Eriba Troll
ST1100
Images: 199
Postby conn.rod » Mon Apr 01, 2013 7:20 pm
dude,your build is getting addicting to watch like the walking dead,don't stay gone so long,btw,it looks good so far
conn.rod
Postby ST1100 » Tue Apr 02, 2013 2:57 am
conn.rod wrote:dude,your build is getting addicting to watch like the walking dead,don't stay gone so long,btw,it looks good so far
Thanks - I take the swiss way - a good thing takes time to build and the double time to think before !
And I need the trailer not before 2014 !
1977 Eriba Troll
ST1100
Images: 199
Postby AlgoDan » Tue Apr 02, 2013 5:54 am
A beauty of a build, I can see the orders coming in now...That is top notch fabrication. Yes very addictive and sweet. :beer: :thumbsup:
Here now but Camping later.............Dan
Build Journal
http://www.tnttt.com/viewtopic.php?f=50&t=54681
102535 103199 105576
From .................Paper...........................To.......................... Pavement............................
AlgoDan
Images: 238
Postby trccc » Tue Apr 02, 2013 6:41 am
I must say that this is quite inspiring. The detail and quality from a simple environment is motivating. Who needs the high dollar shop or big buck tools. A few of the right ones along with a vision and anything is possible! Keep up the great work!
trccc
Images: 52
36: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Tue Apr 09, 2013 4:30 pm
Okay - a weekend without work, celebrating my past birthday at saturday with family, friends, pies, coffee and lasagne :) and at sunday with a great breakfast :)
But now I closed the two holes at the end of my deck with small sheets and the big hole with a tabletop.
Have to build folding legs for the tabletop which fold inside the frame when I sleep upon it.
1977 Eriba Troll
ST1100
Images: 199
37: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Tue Apr 09, 2013 4:40 pm
The grey plastic box will become my step in bay, which can be lowered to the ground below the table to sit in a comfort way.
the connection between trailer and box I will make from tent fabric to prevent mosquitos from visiting my legs.
1977 Eriba Troll
ST1100
Images: 199
Postby S. Heisley » Tue Apr 09, 2013 5:01 pm
:applause: Clever....The hole in the floor reminds me of Wolfarmer's "standy" teardrop but I don't think his has tent fabric.
Postby KCStudly » Tue Apr 09, 2013 7:06 pm
It shows that you ave put a lot of thought into the design. :thumbsup:
I can think of no better way to compliment that than the care and craftsmanship that you are putting into the construction.
Very well done. :thumbsup:
38: Stainless Steel Micro-Airstream behind motorcycle
Postby ST1100 » Thu Apr 11, 2013 3:35 pm
Making the legs for the table is painful and needs much time with my tools !
:cry:
But the result will be satisfying ! It's worth the annoying work !
Cut the four legs and drilled the holes for the screws. That was simple.
But to cut a rectangular hole in which the crossbar fits perfect was a hour work.
But only three more to do !
The second one was faster - maybe tomorrow follows the second double leg.
1977 Eriba Troll
ST1100
Images: 199
