Window trim ring screws
Postby mrslamb » Sun Apr 14, 2013 2:55 pm
I am getting readyto install my front window and purchased the window on eBay.
http://item.mobileweb.ebay.com/viewitem ... 2240819104
The window came with a trim ring but no screws does anyone have any suggestions for which screws to use?
Thanks!
David
mrslamb
Re: Window trim ring screws
Postby CarlLaFong » Sun Apr 14, 2013 3:44 pm
Commercially built trailers use self drilling Tek screws for that type of window. I would lay out a pattern, drill and countersink the holes and use oval head screws. Sheet metal screws will work just fine going into the wood framing and are, usually, easier to find than the typical flathead wood screws that the Borg carries
http://jkcallin.blogspot.com/
CarlLaFong
Images: 5
Postby grant whipp » Sun Apr 14, 2013 6:15 pm
I would highly recommend NOT using tech-tip screws ... depending on the application, you may not have that much room between the groove you screw into and the outside frame of the window, and you may end up running that tech-tip through the face frame. I use #8x1/2" self-tapping pan-head machine screws ... if the wall is a little thicker than the clamp-ring, bump the length by 1/8". A lot really depends on the wall thickness and how the main window frame is made ... there are a lot of variables between window mfgs. and what works for one may not work for another.
Good Luck, and as always ...
CHEERS!
grant whipp
Teardrop Manufacturer
Images: 117
Postby bdosborn » Sun Apr 14, 2013 6:20 pm
grant whipp wrote:I use #8x1/2" self-tapping pan-head machine screws ...
x2.
Images: 806
Postby CarlLaFong » Sun Apr 14, 2013 8:15 pm
Just to be clear, I was not recommending the use of Tek screws, just saying that a lot of manufacturers use them. They are a quick and dirty way to screw things together. Along with drywall screws, they are the most misused fasteners out there.
CarlLaFong
Images: 5
Postby mrslamb » Sun Apr 14, 2013 10:24 pm
Thanks everyone. Good things to think about!
mrslamb
Postby bc toys » Mon Apr 15, 2013 9:59 am
my window trim ring came with #8x3/4 sheet metal screws
bc toys
Images: 42
Postby jeff0520 » Mon Apr 15, 2013 6:05 pm
Ok, on a related note, I have Hehr windows that came without trim rings. I intend to make wooden trim rings by using some 4/4 stock that started out as a waterbed frame, cutting it into 3" wide strips, and putting a 1 x 1 rabbit on one edge. I'll use a compass and my jig saw to make the radiused corners and attach those to the straight pieces with 1/4" dowel joints.
When I install the window, I am aiming for that little "fin" around the edge back from the exterior frame, right? If anyone has pictures of exactly where the screws go, and exactly what I'm supposed to screw into, I'd really appreciate seeing those. Thanks. :)
Hypno-Toad's Command Post, the build thread! http://www.tnttt.com/viewtopic.php?f=50&t=50384
jeff0520
Images: 128
Postby TPMcGinty » Tue Apr 16, 2013 6:35 am
I didn't use trim rings. I screwed the window directly into the door.
Tim
TPMcGinty
Images: 146
Users browsing this forum: Moto_marco and 4 guests
