OverTheTopCargoTrailer wrote:Skip back 3-4 posts, 1 page back and you will see the AC will vent behind the side solar panels
This should keep them mostly hidden , I will suck in fresh air from below the floor , hot air vents up.
Post a Link, I can't find anything.
I also had the idea of bending some white sheet metal to make a Chanel to run my wires inside
By using a 1/2" copper pipe between some boards
The metal could be attached with VHB tape........
I'll make a sample and try to post a picture of what I have in mind .....
With that plan wires would be mostly hidden & protected from damage![]()
Try Panduit Wire Duct. It's the bomb:
Panduit Wire Duct
Jerry
