Another Harbor Freight build
Re: Another Harbor Freight build
Postby Melven » Mon May 06, 2013 3:50 pm
Well I am pretty much done. My wife is going to make some curtains and I have a covor I need to make for the front window but I am calling this complete at this point. Thank you all for following my thread. Thank you for your advice and kind words. Cheers.
Melven
Postby ssrjim » Mon May 06, 2013 4:04 pm
Looks good, now the fun begins.
93079
ssrjim
Postby PKCSPT » Tue May 07, 2013 6:12 am
:applause: very nice
121172 116946 159644
PKCSPT
Images: 61
Postby Melven » Tue May 07, 2013 5:10 pm
Thank you! :)
Melven
Postby TENNJIM » Thu May 09, 2013 2:06 pm
Looks Great! You have done well.
:applause:
Jim B / Utah
TENNJIM
Palladium Donating Member
Images: 35
Postby Melven » Thu May 09, 2013 2:20 pm
TENNJIM wrote:Looks Great! You have done well.
:applause:
Jim B / Utah
Thank you Jim!
Melven
Postby IslandStorm62 » Fri May 24, 2013 11:01 pm
markhusbands wrote:Hey, have you thought about how you will mount your front running lights? I can't think of a way to do it without having wires leading straight into the cabin near your head (while sleeping). Maybe you use the thickness of the roof where it meets the floor?
Hi Mark,
I was just reading threads since I am preparing to start my build. What are these "front running lights" you mentioned? Are these outside the cabin as in headlights? It's just a term I had not run into in the other threads...just want to make sure I did not miss anything. Thanks
IslandStorm62
Postby IslandStorm62 » Fri May 24, 2013 11:16 pm
Melvin,
Great build. I'm in Lacey, WA. Next week I am driving to California to work on my TD with my brother.
Being up here in the NW, I'm concerned about the wood getting damaged with all our wet weather. What kind of stain / sealant did you use?
Also at the beginning of you build, you mentioned a small gap between the frame and your floor...did you shim that up? I am using a HF Tailer as well.
Any advice would be helpful. If you are around and have time, I would like to see a home built HF Teardrop first hand. Let me know and thanks.
Romy
IslandStorm62
Postby markhusbands » Sat May 25, 2013 8:06 am
Hi Mark,
I was just reading threads since I am preparing to start my build. What are these "front running lights" you mentioned? Are these outside the cabin as in headlights? It's just a term I had not run into in the other threads...just want to make sure I did not miss anything. Thanks[/quote]
The amber safety lights that go on the side near the front (outside). Red ones go near the back. People that build foam filled walls can easily run wires through the wall gaps, but us solid walled simpletons only have wiring space over the front wall/roof/hatch. So you have the option of putting the running lights down on the frame and wiring through the frame, or, I guess, daylighting the wire at the front wall edge near where you plan to mount the running light, then routing a shallow wire groove back to where the wire comes our of the fixture. I think I am going to try the latter.
Hope that makes sense. A picture would make it more obvious.
Oh, and not sure what Melvin did, but I stacked washers between my floor sheet and the trailer frame where there were gaps, which is in the front and back. Otherwise your bolts will pull your your floor sheet into a bow.
133923
markhusbands
Images: 58
Postby tac422 » Sat May 25, 2013 12:29 pm
Hi Melvin,
Your build looks great ! I really like it.
I hope you don't mind a couple questions ...
Where did you get the round window from ?
and where did you get your aluminum trim, esp the rain gutter moulding ?
TIA,
tac
tac422
Postby Melven » Tue May 28, 2013 10:45 pm
IslandStorm62 wrote:Melvin,
Romy
I used a stain they recommended at McClendons hardware. It is supposed to be the stain WA uses in all of their state parks to protect their wood. I had it out this last memorial day and it beads the water really well. I will post a pic of the stain when I get home from work so you will know what to buy.
The gap I did not shim. By the time this thing has been put together I cant believe the gap even bothered me. There is no way it will effect anything. You can fill the gap with a construction adhesive or a foam.
I am in Tacoma and you are more then welcome to visit my tear and talk ideas with me. Im glad to help.
Melven
Postby Melven » Tue May 28, 2013 10:54 pm
tac422 wrote:Hi Melvin,
TIA,
tac
The round windows are from a Pinto Cruisin Wagon. I purchased the pair from ebay for 80 dollars. You can also check out the pinto forum to see if you can score a pair.
Here is where I got my trim. http://www.ebay.com/itm/RV-TEARDROP-TRA ... 5890f6c6a3
http://www.ebay.com/itm/RV-Teardrop-Tea ... 5893a78431
http://www.ebay.com/itm/RV-TEARDROP-TRA ... 3cd11b168a
The guy on ebay who I bought my trim from also sold me all my door handles and hinges. He is super good to work with. As for the other 2 inch aluminum trim I have. I bought it at Home depot and formed it to fit my needs. The bottom trim that separates the trailer from the wood was made from 4 foot aluminum strait rulers and flipped around =) alot cheaper that way.
The rain gutters were made from the L door molding in the ebay link I provided. I just happened to have enough scrap to make them.
Melven
Postby Melven » Tue May 28, 2013 11:20 pm
Here are a few pics from my first time out.
Melven
Postby Melven » Tue May 28, 2013 11:21 pm
More
Melven
Postby Melven » Tue May 28, 2013 11:23 pm
More
The window cover was something I made to stop the window from breaking on the road. I made 4 studs and used wing nuts to keep it on. Comes off real easy that way with no tools. ;)
Melven
