TENNJIM wrote:Looks Great! You have done well.
Jim B / Utah
markhusbands wrote:Hey, have you thought about how you will mount your front running lights? I can't think of a way to do it without having wires leading straight into the cabin near your head (while sleeping). Maybe you use the thickness of the roof where it meets the floor?
IslandStorm62 wrote:Melvin,
Great build. I'm in Lacey, WA. Next week I am driving to California to work on my TD with my brother.
Being up here in the NW, I'm concerned about the wood getting damaged with all our wet weather. What kind of stain / sealant did you use?
Also at the beginning of you build, you mentioned a small gap between the frame and your floor...did you shim that up? I am using a HF Tailer as well.
Any advice would be helpful. If you are around and have time, I would like to see a home built HF Teardrop first hand. Let me know and thanks.
Romy
tac422 wrote:Hi Melvin,
Your build looks great ! I really like it.
I hope you don't mind a couple questions ...
Where did you get the round window from ?
and where did you get your aluminum trim, esp the rain gutter moulding ?
TIA,
tac
Users browsing this forum: Bing [Bot] and 5 guests
