Late today I purchased a wireless thermometer and as is normal for Over The Top ...
I installed the wireless unit between the insulation and the silver metal roof. This was at 5:30 PM late today.
Tomorrow it will be much colder so I will have to wait until it gets hot again for additional test results.
inside the temperature was 87 - but under the roof insulation it was still 122 deg F at 5:30 pm
My bet is, the silver roof will hit 130 deg F easy. Here again is where I tell you
at this temperature your solar panels will loose 50% of their output.
I will also experiment with spraying cold water on the roof to see how it brings the temperature down.
I bet none of you have ever thought about cooling your RV or panels down by spraying water on the exterior,
it is very effective because water absorbs heat very fast.
- t1.JPG (94.03 KiB) Viewed 2317 times
It's now 8 PM evening and both temps have equalized. Once fully insulated the opposite readings
should happen at night. Maybe 60 under the skim outside & 75 inside. Time will tell, I plan to install more wired units.
- t2.JPG (112.63 KiB) Viewed 2317 times
Late at night, now the exterior skin temp has fallen bellow the interior temp.
The alum temperature is 68 deg F & inside its 74 deg F
- t3.JPG (110.4 KiB) Viewed 2317 times
