Mark's Teardrop with Roof Top Tent; can sleep four
Postby markhusbands » Tue Apr 16, 2013 10:03 pm
I'm a little late in starting a Build Journal, but then again, I have a long way to go. See photos. For captions, go to the gallery:
104828104829104830104831104832104833104834104837104835
And thanks to everyone who has answered questions for me. I'll be bugging you some more - fair warning.
133923
markhusbands
Images: 58
Re: Mark's Bi-level Teardrop for Four
Postby Melven » Thu Apr 18, 2013 7:37 pm
markhusbands wrote:I'm a little late in starting a Build Journal, but then again, I have a long way to go. See photos. For captions, go to the gallery:
Looks real cool Mark.
Melven
Postby Eric_kc0ahk » Thu Apr 18, 2013 8:19 pm
Never too late!
Eric_kc0ahk
Postby markhusbands » Thu Apr 18, 2013 8:44 pm
Thanks, fellas. Saturday I hope to break away long enough to get some blocking in and partially skin the hatch.
133923
markhusbands
Images: 58
Postby markhusbands » Sat Apr 20, 2013 9:25 pm
Didn't get as far as I wanted, but got edge laminate on the plywood ribs and got the solid oak cross blocking in.
105119 105120
The joints still need some planing and sanding but they'll look a lot better than bare plywood edges.
133923
markhusbands
Images: 58
Postby markhusbands » Sun Apr 21, 2013 7:56 pm
Got part of the skin on today with some help from a friend.
105222 105221 105220
133923
markhusbands
Images: 58
Postby Melven » Mon Apr 22, 2013 6:21 pm
Good progress Mark.
Melven
Postby S. Heisley » Mon Apr 22, 2013 7:52 pm
It looks nice but I don't see the bi-level...? Is that going to be a shelf/bunk for the kids?
You were lucky to have help with skinning that curve. That was the hardest thing for me to do alone. :thumbsup:
Postby markhusbands » Mon Apr 22, 2013 8:20 pm
Eventually it will accommodate a safari style roof top tent as an "upstairs". And I think I would have had trouble getting tight seams without another pair of hands. I did the interior solo and it came okay, but the joints are concealed. My hatch joints will in many place be visible.
133923
markhusbands
Images: 58
Postby davidniebeling » Mon Apr 22, 2013 10:20 pm
Sweet rig! :thumbsup:
davidniebeling
Images: 50
Postby markhusbands » Sat Jun 08, 2013 6:58 pm
Well, I finally made some progress that is actually visible. I've been plugging away at getting the stuff I need for electrical. Still pretty intimidated by the idea of getting it wired and then totally sealing it up. So I decided to tackle a cabinetry item that has also had me nervous. A lesser item is a small cabinet frame in the front to hold the fuse box, mount a reading light, and store small items. The bigger one is a pair of tambour doors in the galley that for me was pretty tricky. First time I ever tried something like this. It worked: see below.
107838
107837
107836
107835
133923
markhusbands
Images: 58
Postby markhusbands » Mon Jun 10, 2013 8:52 pm
I was really excited about how the tambours looked, so I couldn't resist tossing on a coat of stain. I think it will end up looking pretty decent. There's a couple spots where I think I got a glue stain, but it doesn't look too bad, and I don't claim to be a skilled woodworker. It's all experimental for me. I also need to figure out how to make a low profile strip handle for the tambours. Because I used five hatch ribs, the 2nd and 4th hit dead center in the tambour where you might put a knob. I have not quite an inch of clearance, so I am thinking of putting a horizontal strip for a grab. If anyone has an idea let me know.
108011 108010 108009
133923
markhusbands
Images: 58
Postby S. Heisley » Mon Jun 10, 2013 9:36 pm
The tambour doors look really, really nice. :thinking: Will the rain stay out of the tract?
Postby _Ryan_ » Mon Jun 10, 2013 10:41 pm
The doors look great!
As far as the pulls how about using a couple recessed cup pulls. You could cut out a mortise in the lower section and it would fit flush with the front.
_Ryan_
Images: 356
Postby markhusbands » Mon Jun 10, 2013 11:00 pm
Some sort of recessed pull like that is a good idea, although the bottom slat of the tambour is very thin - about 3/16". I'm a bit scared of splitting it. I'd almost like a very shallow oak cup pull, but the shallowest I've seen on the web is .81" projection. Miiiight fit. I'd feel better about .5" - .6". The tambours are light so you don't need much.
And I guess I need to keep rain out of the slats. But if I'm cooking and it is raining I can leave the tambours up and if I'm done and it starts to rain I can close the hatch. The tambours are pretty well tucked up under the hatch so It would have to be blowing. But yeah, letting the tambours get all soaked could warp them I guess. Worth remembering.
133923
markhusbands
Images: 58
