LED lights
Anything electric, AC or DC
LED lights
Postby mustangcats » Mon Jun 10, 2013 10:28 pm
Some of my fixtures use the 921 12 volt bulb. They do a nice job of lighting up the trailer, but put a drain on the battery. I'd like to replace them with LED bulbs but there are so many types in the T10 size, I'm not sure which ones to get. Does anyone know which style of T10 LED bulb most closely resembles the light output of the 12 volt 921 bulb? Some of the LED bulbs are quite pricey, so I'd like to know in advance which ones to get to avoid costly trial and error. I need the bulbs to be able to light up an area instead of casting a narrow beam of light or give off a horrible blue color.
mustangcats
Images: 18
Re: LED lights
Postby _Ryan_ » Mon Jun 10, 2013 11:30 pm
I can't answer your question myself but you should check out [url]superbrightleds.com[/url] if you haven't already.
They have everything and most of the time their descriptions list the brightness, color, and projection angle.
_Ryan_
Images: 356
Re: LED lights
Postby grantstew8 » Tue Jul 30, 2013 8:21 am
I bought some RGB 5050 waterproof LEDS online and I'm putting them inside traditional tail lights.
I've been playing with the wiring and don't have any specific "internal" photos but I'll add some more to tomorrow. I'll add some LED's into some 1970's VW beetle tail lights.
http://youtu.be/zu-ybaC-8ys
:pictures:
grantstew8
Images: 77
Re: LED lights
Postby grantstew8 » Wed Jul 31, 2013 6:29 am
Here is the details on how I've done the lights. With RGB lights, if you use one colour (red for example) only the red part of the LED lights up. If you use white, all three (RGB) light up and is much brighter.
Usual caveats apply, check the regs/laws/standards for using LEDS where you live. :SG
http://youtu.be/3KwjyS-7y14
:pictures:
grantstew8
Images: 77
Re: LED lights
Postby Shadow Catcher » Wed Jul 31, 2013 11:27 am
In our first tear the fixtures took the wedge base, I found LED/SMD arrays that had adapters which I used 3M double stick tape to fasten to the fixture.
54683
Re: LED lights
Postby Pinecone » Mon Sep 02, 2013 12:32 am
I just received these from Amazon. They work well, but the light is more bluish...not warm.
http://www.amazon.com/dp/B0096J90KW/ref=pe_385040_30332200_pe_309540_26725410_item
G. Pang, NW Tear Jerker
Check out Teardrop Event Videos I put together!
IRG 6.0 2016: https://www.youtube.com/results?search_query=IRG+6.0
TOW Promo 2017: https://www.youtube.com/watch?v=mpxgE7H3CrA&t=11s
Pinecone
Images: 28
Re: LED lights
Postby working on it » Mon Sep 02, 2013 12:42 am
Pinecone wrote:I just received these from Amazon. They work well, but the light is more bluish...not warm.
Are you talking about inside cabin lighting? If so, I read (probably here) that blue lighting throws off our circadian rhythm (screws up our sleep cycle), and should be avoided in the sleeping area. I have blue and white lighting in the galley/storage area, and selectable/variable colored lighting in the cabin (all are LEDs). I bought all at Ikea (110vac), and Autozone (12vdc).
173193172890148599
working on it
Images: 457
Re: LED lights
Postby 48Rob » Mon Sep 02, 2013 8:01 am
Pay attention to the lumen output.
Low numbers are low/dim light.
High numbers are brighter.
Rob
48Rob
Re: LED lights
Postby bdosborn » Mon Sep 02, 2013 3:52 pm
You want a "warm white" LED as opposed to "cool". Warm white will be closer to yellow and the cool is more blue. Here's a link to a bunch on eBay. YMMV
eBay linky
Images: 806
Return to Electrical Secrets
