D-rings (update 6-12-13)
Postby les45 » Wed May 29, 2013 11:12 am
I found these neat little d-rings on Ebay. I plan to use them without the plastic backing plate along the existing holes in my NT trailer frame for tie downs. For example, I tie the frame of my Easy-up to the trailer frame as an added safety measure to keep it from blowing away (that's in addition to a stake in each foot). They can also hold down a cover tarp when storing outdoors. They can also be used for many other purposes inside or outside the cabin or galley. The plastic backing cap is 4" in diameter and the center hole is 3/8".
Here is the link to Ebay:
http://www.ebay.com/itm/310394847518?ss ... 1497.l2649
les45
Images: 605
Re: D-rings
Postby RandyG » Wed May 29, 2013 12:15 pm
nice. i plan on using some of these also since I'm always using the rings in the back of my hatchback.
Randy
RandyG
Images: 115
Re: D-rings
Postby Backroads4me » Wed May 29, 2013 2:11 pm
Thank you for posting the link. I looked through the seller's listings and there's a lot of useful looking stuff offered. :thumbsup:
Deb
Backroads4me
Re: D-rings
Postby Rainier70 » Thu May 30, 2013 1:36 pm
If there is a State Trailer Supply near you, they have a nice assortment of D-rings and tie-downs. I have bought and used many of the less expensive ones $1.39, and they are well made and sturdy.
http://www.statetrailer.com/products/Ti ... -track-41/
Rainier70
Images: 244
Re: D-rings
Postby celticquetzel » Sat Jun 01, 2013 11:32 pm
How about inside on lower walls to tie down lawn chairs and maybe extra folding table. I would like to go with 1/8 skins over frame /foam and am worried about gear shifting in transit and punching through the skin.
celticquetzel
Re: D-rings
Postby les45 » Sun Jun 02, 2013 7:02 am
celticquetzel wrote:How about inside on lower walls to tie down lawn chairs and maybe extra folding table. I would like to go with 1/8 skins over frame /foam and am worried about gear shifting in transit and punching through the skin.
You might want to use something a little smaller for inside the cabin. I was kind of surprised at how big these were when I finally received them in the mail (I should have read the fine print). They will work fine on my trailer frame (without the plastic backing plates) but you can find smaller ones for interior use. With the thinner walls, some means of securing your load would be a good idea. I have 3/4" plywood walls and I have a few rub spots from my load shifting around.
les45
Images: 605
Re: D-rings
Postby celticquetzel » Sun Jun 02, 2013 8:36 am
Monsters! But I agree. Perfect for the outside. I'll find smaller ones for inside. Thanks
celticquetzel
Re: D-rings
Postby working on it » Sun Jun 02, 2013 9:02 am
Light duty rings at Home Depot http://www.homedepot.com/p/Keeper-Light-Duty-Anchor-4-Pack-04522/202065707#.UatL1Fko7wo
I have them in several spots in the galley, and in the cabin. Perfect for mounting with 1/4"-20 hardware. Here's one pair on the cabin floor 107315 and another pair on the door frame 102804. I also have several in the galley 105583(most everywhere a bungee cord is, there is another pair).
Last edited by working on it on Sat Jun 29, 2013 11:08 pm, edited 1 time in total.
173193172890148599
working on it
Images: 457
Re: D-rings
Postby Rainier70 » Sun Jun 02, 2013 9:19 am
Good to know that there are more places to pick these up. Tie downs really come in handy.
Rainier70
Images: 244
Re: D-rings
Postby bdosborn » Sun Jun 02, 2013 10:51 am
I have some of these in the truck bed.
They're pretty handy because you can take the out when not needed, or move them around if you get the track:
Macs Tie downs
A little spendy though... :NC
Images: 806
Re: D-rings
Postby Kharn » Mon Jun 03, 2013 7:30 am
bdosborn wrote:I have some of these in the truck bed.
Macs Tie downs
Those are also available from other dealers as "airline track," I plan to use them on my build for holding down the EZ-up, the dog's leash, roof rack, etc.
Kharn
Re: D-rings
Postby les45 » Wed Jun 12, 2013 1:45 pm
Here is a pic of the d-rings installed. I decided to use four on each side for more flexibility.
I found a neat 3/8" button head cap screw on ebay to fasten the rings to the frame (along with a nylon lock nut). I think these look pretty good.
les45
Images: 605
Re: D-rings (update 6-12-13)
Postby Rainier70 » Wed Jun 12, 2013 2:13 pm
They look great. Having more tie-downs is always a good idea.
Rainier70
Images: 244
