GPW wrote:Nice gutter ... very Cool idea !!!![]()
Mary C wrote:I'm watching you!!! looking great!! I like the kerf idea. keep it up your will be unique!!!
Mary C.
Thanks guys.
Mary C.
GPW wrote:George, you could glue something thin like old bedsheets to the tops of the hatch pieces , forming a living hinge on top , and that adds an extra bit of reinforcement under the skin too ...
RandyG wrote:make a mold to keep your radias constant
Audnorge wrote:Please, would you consider doing a short tutorial on just your knowledge of the hot wire cutter: how you build them, the parts needed, how to set up different shapes and jigs? This is the best thing I've seen on the foamie build pages and I need to know about hot wires before I can build the one I see in my head.
Aud
ghcoe wrote:So now that the kitchen is nearly ready to put together I figured that I had better start thinking about the hatch. I was not looking forward to trying to figure out how to do the tight radius on the hatch with foam. I tried a coupe ideas that I had and none seemed to work for me. It finally came down to my last ditch idea that I really did not want to go with because I thought it would be too time consuming.
So the idea came down to cutting small ribs of foam that I will be gluing together. Kind of like kerfing except it is cut all the way through. I made a hot wire jig, yes another one.The jig will make two ribs at a time so it goes pretty quick. I then set them next to each other and attached them together with some packing tape. The idea is that when I am ready to attach the ribs to the hatch that the packing tape will hold them together while the glue sets up. I will be using Great Stuff (GS) down each kerf in hopes of sealing up and gluing the pieces all together to make a nice tight 6" radius roof line. A bit of sanding and it should look great.
Yes, I am being optimistic.
So before I can glue the radius on I need to make the hatch sides stable. One panel is now glued and clamped.![]()
swampjeep wrote:I have not had a chance to try any hot wire cutting myself yet, but I'm curious of this, if you were able to do these rectangle cuts, why could you not cut thin triangles kerfs, leaving maybe 1/4" of foam?
would this be easier the trying to glue a bunch of ribs together?
GPW wrote:George ... Ever think of using The Gripper instead of Gorilla glue .... less messy and it’s already primed... sorta'
