pohukai wrote:The technique you're used is fantastic. If I do another, this is the way I'll do it. What do you plan to use to cover both the inside and outside of the foam?
djdawg wrote:I am a newbie....don't even have a trailer yet and have been debating between using foam or wood. Thank you so much for your pics and step by step process! What you're doing are things that I think I can actually do! It's easy to understand your process with the pics and I like the design of your unit...it's what I was I hoping to do myself. I liked the idea of a foamie but never saw too many with a galley so hence my trouble with deciding. Now I can watch yours come together!
Would you be up for (heck I'd even buy them!) sharing your original plans with dimensions, etc? I know some things have probably changed for you as you've been building it but it would be a nice starting point...
Thanks again!
djdawg wrote:I went back to see if you mentioned it but what type of trailer are you planning on putting this on? Is it used or new and if new where can I get it?
