Ethel has began
Re: Ethel has began
Postby Ben » Fri Jun 21, 2013 5:09 pm
I used screws but need to change them out for larger ones it was all I had and wanted to try it out
Going broke quick fixing a bad start!
Ben
Images: 221
Re: Ethel has began
Postby Ben » Sun Jun 23, 2013 8:26 pm
This was the first idea that I had at installing the ac, well that didn't work out so well I could only get it to run for 7 mins and it would kick out for 20 mins so I knew that that wasn't going to work so i took the cover off the front to give it more air flow, then it would run for 12 mins and shut off for 20 mins. So it was still a no go. So I left it alone for a few days and thought about it.... I had already added 2 -4 1/2" computer fans to draw air from unit and push it out the vent pipe. Well after a few days as 12 pack of beer and a 1/5th of captain Morgan's it came to me.
I need more air flow over the hole coil :hammerhead: so this is what happened I made a cut out the same size as the coil, moved the unit all the way back to the wall and gave it another try.well so far it's run for an hour and the air coming out from the coil is cool! So I hope one a build a duct to connect to the vent pipe all will remain the same. If not I'm going to give 1 more try and add a inline blower. The cabin air is cold so that's what I'm using for the air supply to run through the back of the unit to keep it cool.so if all goes well ill add a vented grill on the inside and some trim and call it done! Well Tuesday I'm off to Texas and won't be back til Friday so next week end ill know more and post another update. Until next time :beer:
Ben
Images: 221
Re: Ethel has began
Postby Silvrzuki77 » Sun Jun 23, 2013 10:34 pm
Soo how did you go about attaching the aluminum?
Silvrzuki77
Re: Ethel has began
Postby Ben » Mon Jun 24, 2013 4:44 am
I haven't yet how r u going to do yours? Lol
Ben
Images: 221
Re: Ethel has began
Postby Silvrzuki77 » Mon Jun 24, 2013 9:10 am
Im just going to use duct tape instead, the shiny kind for ac ducting noone will know the difference :)
Silvrzuki77
Re: Ethel has began
Postby Ben » Fri Jun 28, 2013 9:19 pm
Well I just bought a new tv and here she is
I don't think I'll have any prolbem at Death Valley or Moab now!
Ben
Images: 221
Re: Ethel has began
Postby Silvrzuki77 » Fri Jun 28, 2013 9:23 pm
Nice!!! Even got the offroad edition! Needs some death valley pinstriping now!
Silvrzuki77
Re: Ethel has began
Postby Ben » Fri Jun 28, 2013 9:30 pm
Pin stripping? Not sure what you mean! Lol
Ben
Images: 221
Re: Ethel has began
Postby KCStudly » Fri Jun 28, 2013 9:32 pm
Perhaps he meant "rock rash".
Re: Ethel has began
Postby Ben » Fri Jun 28, 2013 9:41 pm
That's what I was thinking :shock: ill take it easy til she's broke in.
Ben
Images: 221
Re: Ethel has began
Postby Silvrzuki77 » Fri Jun 28, 2013 10:33 pm
You back east folk with no deserts!!! Desert pin stripping is when all the bushes scrap the crap out of your paint
Silvrzuki77
Re: Ethel has began
Postby KCStudly » Fri Jun 28, 2013 11:07 pm
Oh we've got lots of trees and shrubs and briars and plenty of other stuff to scratch up the sides of our junk. Don't you worry! I love wheeling in the woods and the Jeep has plenty of that. It will fit down most trails that are only run by quads. Screeeeetch. It's the dead branches that don't flex anymore that will get you. The green stuff is pretty soft... lots of water here.
I just didn't envision that there was much vegetation out there in Death Valley (although I should know better).
Probably a popular misconception. :?
Re: Ethel has began
Postby working on it » Fri Jun 28, 2013 11:22 pm
Ben wrote:Image
I see that you are having the same problem that I struggled with for a while, though I used a right-angle exhaust duct that was holding in the heat, and causing the thermal shutdown. I ended up adding an inline blower to extract the exhaust heat faster, drilled some holes in my restrictive vent outlet (also to shed heat faster), and lastly I added a 120mm case fan to blow ambient air over the chassis coils. Here's a link to my thread: http://www.tnttt.com/viewtopic.php?f=21&t=54945
173193172890148599
working on it
Images: 457
Ethel has began
Postby Silvrzuki77 » Sat Jun 29, 2013 12:19 am
Yup KC here is a pic of from death valley last year. Not all sand dunes :)
Then sometimes its like this
Silvrzuki77
Re: Ethel has began
Postby KCStudly » Sat Jun 29, 2013 7:40 am
Great pic. :thumbsup:
