My first experiment was to place the 1"x2" flashing around the rear hatch. I glued the flashing on with Gripper. I found that clamping the flashing on distorted it and it was a real pita to try and get it to lay flat along the edges. I finally figured out how to do it and it looked great. I clamped it on a Friday night and unclamped it a week later. The more I looked at it the more I did not like the fact that I could hear the Gripper stick and unstick when I pushed in on the flashing. So, after a week I knew that that Gripper was still wet inside. I did a bit of prying on the edges and yup it came loose fairly easily and yup it was still wet about a 1/4" in from the edges
My second experiment, with a test piece, was with Great Stuff to glue the flashing on. I then tried to pull the flashing off after just 6 hours. The great stuff had nearly full cure all the way to the core. Another few hours and it would have been full cured I believe. Another thing is that the GS expands and make a much better bond all the way across the flashing. So, I will be now using GS for this application. I do believe that over a few weeks that the Gripper will dry, but I do not have that long to wait.
