prohandyman wrote:A variable speed router helps. You need a low RPM to keep from heating up the aluminum too much, which will lead to it sticking to the bit. Router lubricate helps as well as does a sharp router bit.
Dale M. wrote:You can protect aluminum with a layer of masking tape....
Dale
aggie79 wrote:I routed the aluminum without slowing down my router. But...you have to go very slow and deliberately. I used three different style of bits. All did the job. The most effective was a solid carbide "knob" type but designed to trim plastic laminate. I also used a solid carbide down cut spiral bit and a carbide tipped straight cut bit. Both were flush trim bits.
To keep from scratching your aluminum apply two or three layers of masking tape.
On my first day or two I'm sure I was slow and deliberate but you soon learn that a steady even speed will inhibit "chatter" and make a smother finished cut.slow and deliberate
Always run the router in the direction opposite its rotation. Feeding in the direction of rotation is called a climb cut, appropriate for some woodworking operations but not for laminate trimming.be aware that the router will only like traveling in one direction..don't force it.
I have had a one cubic meter shipping container for about 30 years that had punctures when I got it and there are no signs of coming apart. It's 3/8" wall on all sides, the corners are joined with aluminum angle and it has fork lift skids on the bottom. The top is 3/8 with aluminum channel on the edges and two aluminum angles attached to the bottom for rigidity. I wouldn't feel safe trying to fly in it but I strap it to my flat bed trailer and send it down the highway on a regular basis and no signs of anything but ugly. As for wall thickness, most of the cabinets I built were laminated with wood veneer on the exterior and plastic laminate interiors. If I could score enough 1/2 or 3/4" honeycomb to build teardrop walls I think I would laminate the exterior with FRP and the interior would get a layer of thin foam board and thin... something else. In any case it is probably out of my reach. The cost of honeycomb or kevlar is inconsequential to the price of a Gulfstream but would likely score a major hit to my net worth.RandyG wrote:They use those panels on wings and tails all over jets, the skins are usually .020 -.040, very thin.
Even on aircraft they battle moisture with those panels, cause once they get a puncture and get water in it, they delam. But until that happens they are very strong.
markhusbands wrote:Doesn't the aluminum sometimes come with a plastic film that can prevent scratching? I guess I'll find out in another week...
Users browsing this forum: Bing [Bot] and 11 guests
