Trolley Top questions
Re: Trolley Top questions
Postby Ron Dickey » Fri Jul 05, 2013 12:56 pm
Here are some standy type trolley tops really really old and old but made made to look new.
109104
109103
the old but new bellow...
109102rear outside 109101 rear inside
109100 front inside 109099 front outside
the one on the top offers windows the one bellow offers no windows just more head room and is wider.
Ron
173882......173887
Ron Dickey
Images: 787
Postby Ron Dickey » Tue Jul 30, 2013 12:49 am
Another trolley build to add to the list
viewtopic.php?f=50&t=33056
173882......173887
Ron Dickey
Images: 787
Postby 3nero » Tue Jul 30, 2013 3:40 pm
Here's my humble little trolley top.
and this is kind of what i'm aiming at..
Measure once, cut twice....throw away and repeat.
http://www.tnttt.com/viewtopic.php?t=55971
3nero
Postby Ron Dickey » Tue Aug 06, 2013 7:50 pm
As I start to prepare to build mine. I realized how important Center is. Find the Center of the trailer side to side. My trolley will be 14 inches wide. Now I have to figure is that outside to outside or inside to inside and not knowing the thickness of my wood makes the difference.
The front and rear cross bar for the trailer will reinforce it and carry most of the weight.
What thickness do you folks use?
Mine will be 5 inches tall above the top.
Once I know center I can go out 7 inches each way so the trolley will be uniform.
And once the trolley is in place the center bars can be measured can cut to fit.
Mine will be flat on the bottom and will not follow a curve unlike most that I have seen. It fits my skills.
I love seeing those that have the trolley bend around with the arch of their Teardrops.
Nice job guys. :thumbsup: :thumbsup: :thumbsup: :thumbsup:
Ron
173882......173887
Ron Dickey
Images: 787
Postby Irmo Atomics » Tue Aug 13, 2013 1:07 pm
Here's a trolley top that needs a little work:
http://vintagecaravans.proboards.com/in ... 258&page=1
Bob
Irmo Atomics
Images: 64
Postby Ron Dickey » Wed Aug 14, 2013 1:08 pm
whow that is a really old fun one.
I do have a question of those who have put in trolley tops what thickness of wood are you using?
Ron
173882......173887
Ron Dickey
Images: 787
Postby absolutsnwbrdr » Thu Aug 15, 2013 6:52 am
Ron Dickey wrote:Zach
do you have any shots of putting on the cross bars or sheet metal or finished unit.
also what does your Galley look like?
See you are selling your plans hope that is working out.
Ron
Hey Ron,
I've been overlooking this thread somehow and missed your question.
I skinned the narrow roof sections first, and then installed the main roof spars.
Used 50 year latex paintable door and window caulk to create a fillet joint.
And this is pretty much what my galley looks like right now. Just dividers to keep food and stove in place while traveling. The little dividers can be lifted out of slots so I can accommodate whatever items I need. The lower galley is completely open so that I am not so limited to what I can carry for different trips.
Hope this helps!
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Ron Dickey » Sun Aug 25, 2013 10:17 pm
absolutsnwbrdr wrote:
Hey Ron,
Hope this helps!
Nice job :thumbsup: :thumbsup:
did you put in cross bars inside the trolly top? and if so is it sandwiched with top and bottom or exposed from bottom?? :thinking:
Ron
173882......173887
Ron Dickey
Images: 787
Postby Ron Dickey » Tue Sep 03, 2013 5:25 pm
I am thinking of putting tinted plexiglass on the outside and cut out little square windows inside so when we have the light on at night we can put different designs in the squares. Holiday designs, season, camping, forest animals, Kids toys, high contrast photo's etc.
My wife has a christmas tree up all year round, she decorates them 4th of july, Halloween, etc. so she might be keen on what to put in the windows.
Kinda like having a Traveling scrap book :D
Have not started on it but I do have good Idea what it will look like.
107563
also if you go here viewtopic.php?f=50&t=54108&start=75 and look for the cad drawing Junkboy999 did and he did a good job.
:thumbsup: Ron
173882......173887
Ron Dickey
Images: 787
Postby absolutsnwbrdr » Tue Sep 03, 2013 10:12 pm
Ron Dickey wrote:Nice job :thumbsup: :thumbsup:
Ron
Thanks Ron. Yeah there are 1x3 oak cross bars the entire length of the trolley top. They are are exposed, from both top and bottom. Well, there is a screen on top of the cross bars.... and then a removable vinyl cover on top of that.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Kharn » Wed Sep 04, 2013 10:50 am
Zach,
How tall is your trolley top above the walls?
I've been thinking about incorporating one on my Weekender to increase the headroom 4-6" (to make up for the height lost to the 2x4s lifting the bed over the wheel wells), just on the top surface and the upper front face so rather small compared to most, and inset ~8" from each side, so 44" wide.
Kharn
Postby absolutsnwbrdr » Wed Sep 04, 2013 11:32 am
Its right around 6" taller, and it steps in 6 3/4" on each side.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby Ron Dickey » Sun Sep 15, 2013 9:13 pm
for those who have made trolley tops how thick did you do the walls of the trolley?
I guess that would depend on what it was made of.
And what did you insert into the windows? I have many thoughts on this subject but do wonder what you did??? :beautiful:
Ron
173882......173887
Ron Dickey
Images: 787
Postby absolutsnwbrdr » Mon Sep 16, 2013 8:05 am
I just used 3/4" plywood for the trolley-top sides. No insulation. My rear window is clear acrylic sheets from Lowe's. Made a window jamb/frame using quarter-round, pre-drilled small holes through the acrylic, and then used small brass screws and silicone to hold the panels in place. Here are a couple pictures during the construction.
Zach
Coming Soon...
absolutsnwbrdr
Images: 412
Postby doug hodder » Fri Sep 20, 2013 9:52 pm
I used 1/2 MDO for the trolley lift, routed the portholes from the back side which was laminated with birch for the interior appearance, and used tinted auto safety glass for the portholes routed 1/4" deep, glass was bedded with silicone, then mahogany trim rings around each porthole. Doug
