by working on it » Sat Jul 06, 2013 6:28 pm
I never thought I would say this, believing (personally, previously) that teardrops had to be based on a 4x8 plywood board...you need to go bigger, than a standard teardrop, if you plan to take the kids along for 10 or more years. Make room enough for all. Initially drawn to this site by the promise of TEARDROPS 'n TINY TRAILERS, I now see the benefits of larger/different forms for varying needs, i.e. 5x8, 6x10, standys, canned hams, cargo conversions, and even foamies, and other variations. Even pop-ups have their place. If you are planning to buy, get what you need to fit your family, not add to later. If you are building, build what you want, defy convention, and use all the varied ideas from all the sub-forums. IMHO
2013 HHRv "squareback/squaredrop", rugged, 4x8 TTT, 2225 lbs- *3500 lb Dexter EZ-Lube braked axle, 3000 lb.springs, active-progressive bumpstop suspension
- *27 x 8.5-14LT AT tires (x 3) *Weight Distribution system for single-beam tongue
- *100% LED's & GFCI outlets, 3x fans, AM/FM/CD/Aux. *A/C & heat, Optima AGM, inverter & charger(s)
- *extended-run, on-board, 2500w generator *Coleman dual-fuel stove & lantern, Ikea grill, vintage skillet
- *zinc/stainless front & side racks *98"L x 6" diameter rod & reel carrier tube on roof
