I was pleased to be able to discover the pvc sheets. Was familar with FRP and used it as a ceiling material for our TD Cubby, but I believe the PVC will make a better cladding on the bottom. After building the hybrid foamey Puddle Duck sailboat last year, wanted to try a smaller lighter boat (single sailor) that could be easily transported on top of the teardrop.
Should have the boat painted and float tested next week. Later, install sail rigging.
PVC will be great for dragging it on the beach. I built a 9' punt a few years ago and one of the changes I want to make is to replace the bottom runners with plastic, at least at the front where it hits the beach.
Ton’ , we have No Surf !!! Seriously , when we were helping the paddleboarders make their boards, we couldn’t help thinking about how easy it would be to make a Foamie “sit on top” Yak for the local lakes and bayous (Fishing) ... Those were 12’+ boards ... very Light !!
Those "surf" kayaks are designed for whitewater and the like but are not very directionally stable. They are designed to be maneuvered. The paddleboard is meant to go straight and though you can certainly surf it, it is not meant for whitewater kayaking. Except for the facts that they are meant to float and designed for one, they are almost totally different watercraft. Hmmmm, back to the whitewater kayak. One billet, a bit of carving. How to keep the wall thickness even???? Will want a fairly rugged outside shell. You should expect to bounce off of rocks while doing whitewater kayaking.... Maybe selective reinforcement.
Mel
