GPW wrote:Adventurous or enlightened ???Foamies , the Thinking man’s (or Ladies) trailer ...
+1
GPW wrote:Looking Great George !!!!!! ... nice to see the lic. plate on there already ....![]()
atahoekid wrote:I used the same method you did but when I cut the kerfs on mine, I did mine with a Skilsaw with the blade set at 3/4" deep. The blade creates deep kerfs that are somewhat variable in width. I marked the cut lines and freehanded the cuts which allows the saw to twist ever so slightly left and right which cuts wider kerfs than you did with you hot wire cutter. I guess if you used an edge guide and moved it for every cut you would get better kerfs but that would be very time consuming. The saw also creates a mess of pink pellets everywhere. I bought a disposable painters suit to wear when I cut kerfs just so it wouldn't be all over the clothing. I think a hot wire cutter is the way to go!!![]()
