slowcowboy wrote:my thoughts are to upgrade the next teardrop with the room it affords to a little more rv like luxury than a normal teardrop. normaly teardrops don't come with any normal rv applances as they lack room for them and most folks want no hassle with rv applances.
rv furnaces are way easy to maintaine and are a cinche compared to something like a rv fridge wich takes keeping the hole camper leval every where you park or you loose the fridge.
furnaces if you get the right one can be very small and compact to fit most teardrops and they are vented and forced air so there is no open flames and you got good heat blowing out all night long on a small wattage drawing 12 volt blower fan using juice much like fantastic fan vent. they are not hard on propane.
and they are legal to be on all night long with no risk of carbon moxide poisining. you don't have to turn off a rv furnace to sleep at nights like other heators they are fully vented.
this mean you would need just normal blankets to sleep at night and no extra clothing or heavy sleeping bags.
if you get cold at nights you just turn up the themrostate in your camper.
if you get the right one they are automatic on lighting a pilot and the furnace with just a flick of the thermostate switch.
mike on here is a good avadicate of a rv furnace.
only real set back is they start out around 400 bucks but they are darn sure worth it. you won't get them in the smallest teardrop but most of the normal size ones will take a rv furnace.
slow
doug hodder wrote:Maybe I'm the only one that thinks this, however, if you wear little clothes and especially no socks, your body temperature will heat the bed and coverings. It's been my experience that a lot of clothes keep your body heat from radiating and warming the bed. Any latent moisture in a pair of socks will only keep your feet cold. I've camped down to the mid teens in my tears with only an insulated ceiling and been quite comfortable. For those of you that were at one of the early spring Glyphs gatherings, you know what I'm talking about. It always amazes me that someone will complain about being cold and then follow it up with...."I was wearing 2 pairs of socks, long underwear, undershirt etc...." As a side note...alcohol isn't your friend when doing cold weather camping when it comes to sleeping.
hugh wrote: I have no wish to die just yet so i have a battery powered co2 detector.
Tinbasher wrote:Been thinking about an insulated box made to hold some heated bricks with a computer fan to blow air over them, like a storage heater. That should last all night and be safe and virtually free if you heat the bricks in the campfire.
