OverTheTopCargoTrailer wrote:With all my insulation my 7 x 6 x 18 has now become a 6 x 5 x 16 ,
grantstew8 wrote:If you fill a tube with foam it does nothing. The inside is insulated but the heat/cold is transferred around the insulation by the steel, there is no physical break.
Willuz wrote:I used extra wide Gorilla tape to cover the studs and hold the insulation in. It sticks great even in extreme heat and it's thick enough to provide some insulation between the plywood and the metal stud. The most important place to seal is the top of the insulation, otherwise the hot air just rises up and out the top into your trailer.
