How do I attach these lights?
Re: How do I attach these lights?
Postby les45 » Thu Sep 19, 2013 11:02 am
Before using pop rivets for your lights, you need to consider that you might have to remove them sometime in the future. On my first trip, the only problem I had was one of my cabin lights quit working. Turned out to be a loose connection in the fixture wiring but I had to remove the light fixture to figure that out. Try to use screws if you can.
les45
Images: 605
Postby mgb4tim » Thu Sep 19, 2013 11:12 am
les45 wrote:Before using pop rivets for your lights, you need to consider that you might have to remove them sometime in the future. On my first trip, the only problem I had was one of my cabin lights quit working. Turned out to be a loose connection in the fixture wiring but I had to remove the light fixture to figure that out. Try to use screws if you can.
A small drill bit makes for easy rivet removal, especially if its an aluminum rivet.
mgb4tim
Postby tscarbroughdc » Thu Sep 19, 2013 11:49 am
So will this screw not work at all?
tscarbroughdc
Postby len19070 » Thu Sep 19, 2013 1:11 pm
X2 removing rivets is no big Deal.
Happy Trails
Len
len19070
Images: 24
Postby RandyG » Thu Sep 19, 2013 1:26 pm
That screw is counter sunk, it may damage the plastic. If going with screws, as Kc said, use a screw that is flat on the back side of the head.
Randy
RandyG
Images: 115
Postby len19070 » Thu Sep 19, 2013 2:22 pm
RandyG wrote:That screw is counter sunk, it may damage the plastic. If going with screws, as Kc said, use a screw that is flat on the back side of the head.
True, thats not the correct Screw to use. A Pan head would be better.
But!
As long as you put it in Diplomatically....and not use an impact gun or any kind of Power tool, it will work.
Happy Trails
Len
len19070
Images: 24
Postby tscarbroughdc » Thu Sep 19, 2013 3:04 pm
Awesome! Thanks for teaching me all of this! Haha. I know it may be common sense but I'm not a handyman AT ALL!
tscarbroughdc
Postby rowerwet » Fri Sep 20, 2013 8:10 am
len19070 wrote:I'd use a Pop Rivet!
The one on the right.
Happy Trails
Len
these type of rivets are used to mount cleats on plastic kayaks, I just got some from west marine, they are also on ebay
rowerwet
Images: 521
Postby len19070 » Fri Sep 20, 2013 9:44 am
rowerwet wrote:these type of rivets are used to mount cleats on plastic kayaks, I just got some from west marine, they are also on ebay
:thumbsup: :thumbsup:
Happy Trails
Len
len19070
Images: 24
Postby KCStudly » Fri Sep 20, 2013 9:52 am
West Marine Tri Grip Rivets $6.99 per 10 pack with what appears to be an o-ring gasket under the head.
Yak-Gear Tri Grip Rivets $5.74 per 10 pack, does not appear to include a gasket.
Thanks for the info. :thumbsup:
Postby len19070 » Fri Sep 20, 2013 10:28 am
len19070
Images: 24
