atahoekid wrote:You might want to check out Goldbrand trailers. they've got an interesting website and they build trailers for pulling behind a motorcycle with foam, fiberglass and aluminum. You might get some ideas.
ghcoe wrote:This is one product the wood canvas canoe builder/restorers are using. I will be giving it a try on my foamie.
http://www.wayfair.com/Foster-Products- ... I1005.html
atahoekid wrote:I used fiberglass on my Road Foamie mostly becuase I wanted an automotive smooth finish. It turns out that it was a lot more work than I wanted to do and working under a deadline made it impossible for me to take the time to put on enough coats. (I'd have liked to do two more coats)
GPW wrote:Mel , sorry for not thinking about that sooner ... it was right under my nose all the time ...![]()
http://www.utrechtart.com/Utrecht-Profe ... 38.utrecht
A gallon goes a long way ... I like to use a small plastic spreader for the first coat ... that levels the surface , more coats brushed on just makes it smoother ... being Acrylic it remains flexible and waterproof , perfect for our needs ...
Users browsing this forum: DrAlvarez and 17 guests
