Serious and planning my first Teardrop
Re: Serious and planning my first Teardrop
Postby Fyddler » Sun Jul 28, 2013 6:59 pm
Ha! My cousin was camping with us this weekend with a similar trailer. They were sleeping in the bed of their truck and I told them the same thing! Throw a roof on it and your set!
To err is human, to really foul up requires a computer
Build Log: http://www.tnttt.com/viewtopic.php?f=50&t=55017
Fyddler
Postby be_a_jayhawk » Mon Jul 29, 2013 9:20 am
Haha...but too late it was a trash trailer and the walls and floor are already gone!
be_a_jayhawk
Postby bc toys » Mon Jul 29, 2013 1:40 pm
Welcome to site just cut off the rails and start over you'll have a nice trailer in no time good luck
bc toys
Images: 42
Postby be_a_jayhawk » Mon Jul 29, 2013 8:21 pm
There she is all stripped down of wood. Much lighter now! Next question is what is the best way to remove the rails cleanly? Cut grind or torch?
be_a_jayhawk
Postby Forrest747 » Tue Jul 30, 2013 12:47 pm
torch then grind smooth
Forrest747
Cowbell Donating Member
Images: 447
Postby Junkboy999 » Tue Jul 30, 2013 1:00 pm
Torch is faster less work on your part, A good reciprocating saw and a few good blades will work but will shake you to pieces.
Are you planing to build out past the side of the frame ? If so you can keep the one extenders (maybe license plate was on it) and the ones holding on the fenders. Hate to cut off parts that you might be able to use. ( if you're going wider )
Junkboy999
Images: 52
Postby be_a_jayhawk » Tue Jul 30, 2013 2:55 pm
I plan on sticking with 5 and squeezing a queen in there. Hopefully I can keep the walls thin enough so I don't have to drop to a full.
be_a_jayhawk
Postby be_a_jayhawk » Mon Sep 02, 2013 8:40 am
Back to work this weekend. Chopped the rails off and onto the tedious grinding of the edges and rust spots. Any grinding tips would be welcome. It sure did lighten her up.
be_a_jayhawk
Postby David S » Fri Sep 06, 2013 1:01 pm
Welcome from another Kansan.
I am building a 5 wide ,feel free to look at my build journal. Rock Chalk!
David S
Images: 53
Postby be_a_jayhawk » Sat Oct 12, 2013 4:23 pm
Thanks, I am still working on cleaning up the frame. I want to get it sanded and painted. Hopefully then I can really make some progress too. I have some big design ideas I hope I have enough skills to pull them off.
be_a_jayhawk
Postby bc toys » Sun Oct 13, 2013 8:20 am
Hang in there you have the skills to do it
bc toys
Images: 42
Postby rowerwet » Sun Oct 13, 2013 3:43 pm
if you look at camp Inn they have a design with a bunkbed in the raindrop design, good find with the trailer :thumbsup:
I looked at Harbor Freight, but the axle just didn't do it for me. I bought a new Tractor supply trailer for about as much money as the Dexter axle costs by itself.
I have two tent trailers I got free for future builds, one has a Torflex axle and the other has a Dexter, both are much better.
rowerwet
Images: 521
Postby Nate.petty » Sun Oct 13, 2013 4:14 pm
looking good. Good progress, ill have to watch this build! keep it up!
Nate.petty
Postby be_a_jayhawk » Thu Jan 09, 2014 11:13 pm
Too cold to work so time to sketch.
rough trailer sketch.png (19.81 KiB) Viewed 546 times
be_a_jayhawk
Postby be_a_jayhawk » Sun Jan 12, 2014 4:25 pm
With the nice warm weekend I hit her with a final coat of paint. Next up the flooring!
be_a_jayhawk
