Sheri and I enjoyed meeting you and your lovely wife immensely!! The Super Bee is a very well build tear and shows a lot of craftsmanship that you put in it! Hope we can camp together sometime and meet again.
Cliff
kd5edj63 wrote:. What grade of plywood did you use. It does not appear to be birch
rebapuck wrote:Are you happy with putting the coolers under the countertop?
Tobit wrote:What a great Weekender. After seeing this build, along with Whitney's and starleen's, I think I'm going to build one instead of a standy like I was thinking. However, I think I'm going to make mine a bit taller and with a single 30"x75" elevated bunk that I can sit on fully upright like a couch. 58" interior height seems about right. That shouldn't be too tall, eh?
les45 wrote:No new pics, but I hit a major milestone today while putting everything back together after completing my painting. This was the first time that I had everything in my electrical system connected to my Progresssive 4045 converter/charger. Hooked up my shore power and started flipping breakers and no surprises. Everything worked exactly as it should. AC/DC with and without the battery. It's a little overkill for my 20 amp system, but it sure is nice. I had a bit of a scare when I checked my outlets and they showed an open ground. Turned out it was a faulty extension cord (cheapo from HF; just because you have a ground prong doesn't mean you have a ground). When I connected my new longer/heavier cord that I will be using with the weekender, everything checked out perfectly. I see camping in the near future just in time for the cooler weather.
les45 wrote:... gives me more time to keep filling those little cracks and dings that keep showing up every time you look at it in a different light. I've gotten two coats of Zinsser oil based primer on so far but have sanded half of it off to keep working the little blemishes. Today was another day of 100% humidity so no primer but another day of filler. Good thing I ordered "too much" of the Smith's Fill-it. Weatherman is calling for a dry spell next week so after some more filling and sanding this week, I'll be ready to start slinging paint again. Still gotta get two full coats of primer before the three coats of Rustoleum. It's gonna be a long month.
Primer, sand, fill, and sand some more. Primer, sand, fill, and sand some more, etc. etc.
Good thing I bought too much of this stuff.
les45 wrote: Used Aeromarine 300/21 system (thanks to CliffinGA) with 4" tape. I wetted it in heavy with a 2" chip brush and then rolled it out with a 4" high density foam roller. I don't recall seeing this mentioned anywhere, but you have to use a tipping brush to get all the air bubbles out after you roll out the epoxy (very similar to an epoxy paint). Four and half ounces of mix and about 100" of tape is about all I could get done in each batch before it started setting up. Temp was about 80 degrees. Used a lot of disposable cups, sticks, chip brushes, and rubber gloves. Also used lots of drop cloths because it drips all over, especially working vertical joints and bottom bevels. Acetone cleans up pretty well as long as the stuff is still sticky.
I'll start smoothing it out tomorrow with more coats of epoxy to fill in the fiberglass weave and feather the edges.
IslandStorm62 wrote:
Excellent work. Unfortunately for me it means I have to rethink everything about life and building a TD...lol. Can you explain how you connected your Shore power to the PD4045. Is it just a Extension cord with the end cutoff or did you build a inlet plug and run a 14/3 cable to the Main 120VAC Breaker in the PD4045? If you don't mind could you list the parts?
Also, going back a few pages, you used fiberglass tape to seal the outside edges of your wall and roof. Can that same technique be used if I was just planning on staining and sealing? Back when I started this project I had planned on just having a woody (stained and sealed). My trailer is being built with Baltic Birch 1/2" and 1"8"...now I am thinking of painting as you did, but I have to check the cost and remain on budget. As a matter of fact, my budget got cut just a wee bit this year. Thanks again.
IslandStorm62 wrote:I do not recall the material you used for your trailer. My wall is 1/2" Baltic Birch and 1/8" Baltic Birch for the roof/skin. They appear to be fairly smooth. I moght do a light sanding to clean it up. So, I was wondering if you think all the filling you are having to do is related to the material you used or can I expect the same amount of filling sanding and primering?
I'm sure the edges that are sealed with the fiberglass tape will require additional filling and sanding.
Users browsing this forum: jdeleon and 4 guests
