Perhaps rip some thin slats to use as fillers (many people do this), or even a row of paint stir sticks.
I would be concerned that felt would collect and hold moisture.
WitsRUs wrote:Thank you KC and Ryan for the tip on filling the gap!
Today I got the shipment of two doors, roof vent, 9"x44" window, and hurricane hinge! The only issue was that the delivery person dropped it on the porch of 3102 instead of mine at 3201! Thank you kind neighbor for coming over to tell me!
I also put on a a second coat of the Fence Post Asphalt Paint today and removed the taping. It was a very easy application with a brush for the first coat then a roller for the second coat. Like Ryan found, it was not nearly as messy as I thought it was going to be.
Starting the first coat with a brush.
After the fist coat is complete.
After the second coat with a roller and after the masking is removed.
_Ryan_ wrote:One thing I noticed as I was completing my build was that that there was a gap ( about 1/8" ) between the underside deck and the crossmembers of the Northern Tool trailer. This gap was the result of the way the cross members were attached to the inside of the side rails on the trailer.
It wasn't a big deal, but it did creak a bit when I jumped onto the deck. I solved this issue by inserting a few felt bumpers ( the kind for the feet of chairs to protect hardwood floors). You might think about installing a couple rubber pads or some type of window flashing over the trailer cross members before permanently attaching the deck.
KCStudly wrote:I would be concerned that felt would collect and hold moisture.
Users browsing this forum: Bing [Bot] and 10 guests
