denverd0n wrote:So, on your camper you used 1/8" ply for the inside walls and aluminun on the outside. Right? Have you ever had any trouble with the 1/8" being too thin? Like, does it flex when you lean against it?
The reason I ask is because I'm trying to decide if I want to make my sandwich walls using 1/8" ply inside and out, or 1/4" ply inside and out, or maybe 1/8" on one side and 1/4" on the other side (though I haven't decided if it would make more sense to have the thicker wall inside or out).
Whatever I use for the walls it will be 3/4" thick stock for the framing. Any advice?
mikeschn wrote:My big box store right around the corner from me with the orange roof only has the 1/4" luan. To get the 1/8" stuff I have to go to Pontiac plywood. The 1/8" stuff definitely exists, but it's not as popular as the thicker stuff... so most folks will have to look a little harder for it!!!
wired74z wrote:Here's an arcticle from Workbench magazine. I managed to dig my copy out last night. The paper magazine has a longer article than the online version.
http://www.workbenchmagazine.com/main/276-torsion.htm
I've been thinking of using this method to build all of the flat sections for a teardrop trailer. Just add insulation and wiring as you build the panels. I'm thinking of using pocket screws to assemble the frame before attaching the skins.
Would 1/4" skins inside and out be enough? Or should I use 1/2" on the outside? Living in Minnesota, an insulated camper is almost mandatory!
