How do you make the hole larger
Re: How do you make the hole larger
Postby Shadow Catcher » Thu Nov 07, 2013 7:17 pm
I managed to pick up the 2 5/8 hole saw today at Home Depot for about $13. I used brass stock for the cover plate and have a couple more so I can redo another one with a neat hole, use that as the guide for the final hole widening. And yes slow there are some projects where a stick of 20%... :cigar:
Postby Tinbasher » Fri Nov 08, 2013 3:41 am
Shadow Catcher wrote:I managed to pick up the 2 5/8 hole saw today at Home Depot for about $13. I used brass stock for the cover plate and have a couple more so I can redo another one with a neat hole, use that as the guide for the final hole widening. And yes slow there are some projects where a stick of 20%... :cigar:
Glad you got fixed Shado, I found this a fascinating thread reading all the clever ways our fellow builders got round the problem.
A person can never own too many tools or have too many ideas or have too much interesting and useful stuff in the garage.
Tinbasher
Postby Shadow Catcher » Sun Nov 10, 2013 9:22 pm
I managed to finish the install today, Here are the before and after. Note in the after shot the reading of the voltage from the solar panel which is in full shade.
114209114210
Postby tony.latham » Sun Nov 10, 2013 9:50 pm
Shadow Catcher wrote:I managed to finish the install today, Here are the before and after. Note in the after shot the reading of the voltage from the solar panel which is in full shade.
114209114210
Dang fine fix.
I've got two 30 watt panels coming this week. What's the 3008 mean?
TL
Postby Shadow Catcher » Sun Nov 10, 2013 10:05 pm
30.08 volts, the comment was more for those who are contemplating solar. The point is that a high voltage panel produces usable current when a conventional 12V panel is not producing anything.
