by les45 » Sat Nov 16, 2013 8:48 pm
+1 on what Tom said. You should have instructions with the components. Mine was from Smith and Co. and it mixed 1:1. I used the polyethylene (frosted) type plastic cups for mixing. I marked a 3 oz line on each of two cups and used them to measure equal parts of the two components, A and B. I then poured them into a third cup for mixing. I used a rectangular 6X8" shallow tupperware container to hold the mix while I rolled it on with a 4" foam roller (you could probably use the small plastic roller pans). You will need a good quality foam roller since the mix will eventually melt the cheaper rollers and the foam will swell and start breaking up as you apply. You could brush it on too but I found the roller to be much quicker. CPES has a fairly long pot life so you could mix a lot more than I did at one time. Also, like Tom said, make sure you have good ventilation or wear a respirator.
