Furnace idea.
Re: Furnace idea.
Postby rowerwet » Sun Nov 24, 2013 3:38 pm
mikeschn wrote:Did you guys see the candle furnace that Paul Elkins came up with? here: http://tnttt.com/viewtopic.php?p=1050017#p1050017
the only advantage I see here is interior light, for heat the exhaust is placed so high you will get some, but most will run right out the top. in a tiny space like the pod It would be fine, especially for someone aclimated to the outdoors most of the day.
for those of us who live in houses, cars, and other heated spaces I don't see nearlly the efficiency the boxes of the cookie box heater give, each box traps a pool of heated air in the top (as long the the air passages and exhaust are placed low) forcing most of the heat into the metal.
of course in this heater you want a good flow of air, otherwise the glass will soot up quickly
rowerwet
Images: 521
Re: Furnace idea.
Postby rowerwet » Sun Nov 24, 2013 3:41 pm
mikeschn wrote:Did we ever decide what's the best way to handle stratification of heat in something tiny like a teardrop?
heat under the lowest part of the floor will take care of most of the problem (the reason the floor furnace is mounted there instead of on the wall) a fan will be needed if that isn't enough
rowerwet
Images: 521
Re: Furnace idea.
Postby rowerwet » Sun Nov 24, 2013 3:47 pm
mikeschn wrote:KC,
Do you think those fin thingies would help with a candle heater?
Anyways, I've got 2 candle heaters ready to ship down to Rev Floyd to test in the pods. Keep your fingers crossed! :thumbsup:
I wonder if the effort to put fins on the boxes is really worth it, testing a cookie tin heater in one of you pods, one with fins and one without, and recording the pod interior and exterior temps over 6-8 hours with the same number of candles would be the only way to put the theory to the test.
you will get more heat out with the inner and outer fins idea, enough to go to all the effort? not sure, only the thermometer will tell.
rowerwet
Images: 521
Re: Furnace idea.
Postby oakinteriors1 » Sun Nov 24, 2013 6:03 pm
With needing some fresh outside air in the trailer why have an outside air intake for the heater, just one exhaust hole in the trailer side would be all you need..
oakinteriors1
Re: Furnace idea.
Postby mikeschn » Sun Nov 24, 2013 6:21 pm
RandyG wrote:Not sure if anyone would be interested here, it's a little big for inside a TD, but people have also made stoves and heaters with ammo cans. You would need to build a heat barrier on your walls cause they can get really hot, enough to heat a large tent in freezing temps. I have had one in my 'To-build' list for a while.
Those are typically liquid fueled, and very dangerous in something like a pod or a teardrop.
Re: Furnace idea.
Postby RandyG » Sun Nov 24, 2013 6:51 pm
The ones I have seen burn small sticks, no liquid fuel.
Randy
RandyG
Images: 115
Re: Furnace idea.
Postby Ron Dickey » Mon Nov 25, 2013 1:24 am
mikeschn wrote:I'm going the supermarket today sometime. I am going to look for round cans with cookie tin lids. I think I want to try doing a miniature version of the double barrel stove.
Terry, that looks like the triple version of that stove, with out the spaces inbetween stoves!
this time of year most places offer Pop Corn Tins.
they have cookie tin tops.
Ron
173882......173887
Ron Dickey
Images: 787
Re: Furnace idea.
Postby Ron Dickey » Mon Nov 25, 2013 1:33 am
Junkboy999 wrote:Wow this is a fun thread. Only thing I worried about is, the price of cookies Tins going up now that everyone is going to make a heater out of them.
I know from having a bout with oxygen deprivation in April, when it was 26 Deg outside and I closed my top vent and window a little too much, that it is important to have a good fresh air exchange. Could we use a small heater like with a long inlet tube located low on the floor and vented out the side or top, to help pull out the the heavier carbon dioxide outside? This will make a siphon exact and bring in a little more cold air from the windows. Wondering what effect it would have on the candles.
A round one might be fun to try. The top two cans and the lid of the bottom one can be bolted together. It will make for better heat transfer up. You might have to unplugging the exhaust vent from the trailer to open the stack up.
shouldn't the bottom tube he at the height of the flame? the air in could go out the in!! The rest makes sense to me. I like the concept
Ron
173882......173887
Ron Dickey
Images: 787
Re: Furnace idea.
Postby Ron Dickey » Mon Nov 25, 2013 2:01 am
Ron
Mike how about this Image
around upper or lower tube?
173882......173887
Ron Dickey
Images: 787
Re: Furnace idea.
Postby Ron Dickey » Mon Nov 25, 2013 2:09 am
look a little big but if you go to Google image and put in ammo Box furnace you will see a lot. seems like they will work out of doors or sheltered area. Look real real real warm!! :)
Nice idea.
Ron
173882......173887
Ron Dickey
Images: 787
Re: Furnace idea.
Postby RandyG » Mon Nov 25, 2013 8:07 am
Ron
As long as the inlet is lower than the first transfer tube it should work.
Randy
RandyG
Images: 115
Re: Furnace idea.
Postby Martiangod » Mon Nov 25, 2013 10:30 am
A little more complex but heres a cool, ahmm, hot little project stove, guy made it for a sailboat, he burns charcole brickets in it....6" by 6" steel box
http://www.duckworksmagazine.com/12/howto/woodstove/
Chris
Deep in the Heart of Nowhere
Martiangod
Images: 432
Re: Furnace idea.
Postby mikeschn » Mon Nov 25, 2013 5:15 pm
I'm testing the cookie tin candle heater right now outside in the pod.
I've got 6 candles running.
First 3 of the candles went out. So I cracked the tin so it would get more air. Now the candles are staying lit.
Starting temp 39°F.
19 minutes later: 41°F.
Re: Furnace idea.
Postby mikeschn » Mon Nov 25, 2013 5:17 pm
This is starting to look better all the time...
http://www.nuwaystove.com/model965.php
Re: Furnace idea.
Postby mikeschn » Mon Nov 25, 2013 6:16 pm
Next test. I threw the Coleman BlackCat PerfecTemp Catalytic Heater out there, and lets see what happens. It supposedly throws out 3000 btus on high.
http://www.walmart.com/ip/Coleman-Black ... r/13228605
