KCStudly wrote: Used a 16 gal wet/dry vac and bubble wrap as a breather felt medium.
pmowers wrote:A shop vac was used to pull the vacuum, and just left running for 24 hours.
angib wrote:pmowers wrote:A shop vac was used to pull the vacuum, and just left running for 24 hours.
I've seen that before and it's a big cost saving over a vacuum pump. But how many times can a shop vac be left running for 24 hours before it burns out the motor? They're not designed to draw no air and while a shop vac is cheaper than a vacuum pump, a new shop vac every two, five or ten pulls isn't that cheap.
bdosborn wrote:I also used titebond II glue, which has a set time of 1/2 hour, so I only clamped mine for an hour or two.
bdosborn wrote:angib wrote:pmowers wrote:A shop vac was used to pull the vacuum, and just left running for 24 hours.
That's what I thought too but that's not what happens. The shop vac motor is actually unloaded when the vacuum is highest, drawing less current than when it sucking a lot of air. Mine runs surprisingly cool and heat is not the issue I thought it would be. I have a purpose built vacuum pump and ditched it in favor of the shop vac, the shop vac worked much better. The higher volume of the shop vac compensated for all the little leaks in the taped seams better. I also used titebond II glue, which has a set time of 1/2 hour, so I only clamped mine for an hour or two.
Required pressure application
100-250 psi, depending on substrates
