KCStudly wrote:This topic is a revolving door that comes around like clockwork.
KCStudly wrote:The people (like myself) who are pioneering methods of light weight (...or semi-light weight) construction are using the insulation as a part of composite construction (as a structural aspect).
KCStudly wrote:Plywood is fast, easy, and probably less expensive.
Insulated stick walls have the potential to be lighter, quieter, and more comfortable.
KCStudly wrote:I'm with the foamies: 1-1/2 thk foam with minimal cedar framing; 5 mm Okoume marine ply inner skins; and, when I get to that stage, canvas, glue and paint outer skins. No trim, full canvas wrap.
DMcCam wrote:Our walls are 3/4" skeletonized plywood with rigid insulation sandwiched between two 1/8" Baltic birch layers for a 1" wall. The walls took about 30 hours to make plus waiting for glue to dry. Was it worth it? For us it was.
Happy building,
Dave
bdosborn wrote:Where do you plan on camping? California builders often skip the insulation, Colorado builders often insulate.
KCStudly wrote:Sorry numumzu. There is seldom going to be one easy answer to a question, and it wouldn't be right for me to be so presumptuous to make the decision for you. I have tried to give you a few more details and opinions that I have read, that maybe you have not, so that you can make a more informed decision for yourself.
I understand your frustration at this stage of the game and will take your comments in stride, hopefully in the good humored manner that it was intended(?). Sorry about the noob comment.![]()
2bits wrote:I think your comment of: "perhaps down to 20' " tells me what range you are willing to camp in. So if the LOW range is in the 20's, that is the same as me and I live in Texas.
2bits wrote:To be honest, even a drafty teardrop made out of cardboard and duct tape will still be nicely heated with a tiny heater due to the small area that you are heating (or cooling). It is just my opinion but all the other conversation is academic IF you have a heater. This assumes you will be camping at a state park or otherwise location that supplies power for a heater, if that is not the case, then my assertions do not apply at all and the academic approach is extremely relevant, at which time I would still support the solid plywood walls.
2bits wrote:If I were to do a frame method, I really like the skeleton method of taking a piece of plywood and removing the non-structural sections and replacing with insulation!
I hope that helps!
