RandyG wrote:Mine is only about 44" from the rear, I figured there is no way to calculate how much total weight I will end up with so a guess was the best I could do. Once all built I can move things around to get the best tongue weight. The framing in the front of the Raindrop is a little bit heavier than a teardrop but not much. What kind of Tv are you using?
RandyG wrote:Since you are using larger tv's, you can move the axle back a little and take a little more tongue weight and it will track better. The axle position is more critical if using a small tv, you have to balance it just right. I think too far back would be better than too far forward in your case.
Gunguy05 wrote:One thing I am trying to work out right now is how far to bring my Aluminum (if we don't paint it) down. Do I take it over the wall, to the frame, or overlap the frame so there is no external frame showing.
My issue is the bow on the front and where it hangs out over the sides. My inital thought was to cover the sides including the frame... but. When I think about the radius on the front, that will mean I will have 4 inches of Al hanging over the edge (the thickness of the side frame rails), with only 1/8 ply behind it (the outer skin beneath the Al). My other thought is to make a frame behind that overhang, and just have it attached to the bottom side of the floor that is above it.
It just seems like with only the 1/8 behind it, it will get bent, chipped and damaged very easily.
Does this make sense? Suggestions from others? I'm sure there is any easy fix here... and I really don't want that 4" of frame showing if I can help it. We are going to talk to a welder on Sat am, so trying to work a few things out.
Brian
Brian
