Canvas and paint thickness galley gap
Postby RogHodge » Sat Feb 01, 2014 2:13 pm
If you all don't mind. I would like a little feedback. How thick is the basic canvas paint layer? I need to allow for that I believe as I set up my galley. Right? Also if you have a look at the pic I'm wondering how much of a gap to allow for on the wall to boot lid. Does this make any sense?
Stand by and I'll ad better pics
For those who would like to have a look I have a build journal and covet your feedback.
http://www.tnttt.com/viewtopic.php?t=33547
RogHodge
Images: 51
Re: Canvas and paint thickness galley gap
Postby RogHodge » Sat Feb 01, 2014 2:28 pm
Maybe these will help, or confuse the matter.
RogHodge
Images: 51
Postby rowerwet » Sat Feb 01, 2014 5:54 pm
it will really depend on the canvas you use, your best bet would be to make up a sample with the paint and canvas you plan to use on a piece of foam, then after it dries cut it in half. you will be able to get the best idea that way.
rowerwet
Images: 521
Postby atahoekid » Sat Feb 01, 2014 6:43 pm
Ditto that. The gap you need will depend on the weight of the canvas and how thickly you apply the paint. Wish there were a simpler answer than running a trial.
Mel
atahoekid
Images: 158
Postby RogHodge » Sat Feb 01, 2014 6:51 pm
Well crud :NC
How about this...
How much gap do I want when it's finished? For gasket? Ballpark, cause I know you are going to say... "It depends on the gasket you plan to use..."
Feel free to tell me what to use
RogHodge
Images: 51
Postby atahoekid » Sat Feb 01, 2014 6:55 pm
Sorry I can't be of more help, but I have flat "cargo" style doors in the back so I never came up with that problem. I think Grant at Lil Bear sells the Hurricane Hinge and he should be able to tell you how much gap to leave. The Hurricane Hinge seems to be widely accepted as the best hinge for the hatch.
Mel
atahoekid
Images: 158
Postby RogHodge » Sat Feb 01, 2014 8:04 pm
I'm going with living plastic
Thanks though,
I'm thinking 3/8 should be sufficient
RogHodge
Images: 51
Postby GPW » Sat Feb 01, 2014 8:50 pm
Rog, I think I’d make the gap just maybe a eighth of an inch smaller than the gasket thickness...again , depending on the gasket material ... :thinking:
Postby rowerwet » Sat Feb 01, 2014 9:28 pm
my galley hinge is also live plastic, I don't have any gasket underneath it, the hinge is waterproof if installed correctly. (just don't goof like I did and cut the hinge shorter, leave it full length, if it sticks off the sides of the tear trim it flush to them but that is it, the hinge is a great gutter when the galley is open)
I made my hatch top flush with the galley wall/roof end then stuck the hinge on over it.
rowerwet
Images: 521
Postby Jst83 » Sun Feb 02, 2014 2:19 pm
My lid practicly touches the side and as foam compresses I figure very little space is really needed under the lip
Not to hyjack this thread but where did you get you plastic hinge I thought I got mine years ago from McMaster car but when I looked I don't remember it being that expensive and I might use that on my present build?
Sorry back to the topic at hand.
Jst83
Images: 215
Postby RogHodge » Sun Feb 02, 2014 5:38 pm
No worries, I saw mcmasters prices and kept looking. Plus they sell 4 or 8 ft.. A foot to short or three to long.
Any way I plan to buy from this guy
http://www.ebay.com/itm/RV-TEARDROP-TRA ... 1325577703
Better size, better price
RogHodge
Images: 51
Postby rowerwet » Sun Feb 02, 2014 7:19 pm
Fleabay also
rowerwet
Images: 521
Postby Jst83 » Sun Feb 02, 2014 9:35 pm
Found this one 6' for 8.82 only 1 1/2" wide but might work for me my galley is 6'3" wide but I've inly got 3 small hinges on it now
http://www.usplastic.com/catalog/item.aspx?itemid=23843
Thanks for the info.
Jst83
Images: 215
Users browsing this forum: jgmahoney and 6 guests
