Colorado_Carter wrote:I had a little distortion after building the rear hatch, I took a 1/2" flush trim router bit and with the hatch closed ran the router bit along the inside of the hatch to leave an exact profile of the the hatch. It also left room for weather stripping. Based on my experience now I would try a smaller 1/4" or 3/8" flush bit and shave off a bit at a time.
I agree that this is the easy quick fix, once the doors are removed get you some clay or silly putty and put it on the corner of the existing cabinets, close the lid and it will show you just how much room you have to correct and modify.Woodbutcher wrote:If the hatch closed before the doors were installed then remove the doors. If they were installed on a face frame, you could trim the doors down and make them inset doors. Those are doors mounted on the same plane as the face frame and would not protrude into the space. All the doors and face frames would be flush.
