Turtleback Trailer Build - From the Manufacturer
Postby DZRTDAVE » Tue Jan 28, 2014 10:01 pm
orange open sm.jpg (189.71 KiB) Viewed 1366 times
My name is Dave Munsterman, Owner of Turtleback Trailers LLC I love the camping industry and camping way of life. We manufacture small off road styled camping trailers in Phoenix AZ. http://www.turtlebacktrailers.com or https://www.facebook.com/turtlebacktrailers
I am going to start a build thread of a Turtleback 4x6 Expedition Inspired camp trailer here on TNTT showing how our units are built from start to finish. I'll show you all of the parts used and explain why if you would like. I know that some will have differing opinions yet this is what I have seen to be the best way from my fabrication and life experiences to create a unit that will last the test of time and not break the bank.
Next week I'll start with the frame and hopefully give enough detail to spur some interest in a thread.
Happy camping and creating,
Dave
Turtleback Trailers™, Home of the most versatile & rugged adventure inspired trailers made. Our affordable camping units are light enough to pull behind most any vehicle and rugged enough to take up the Rubicon or Denali. We're Made in the USA with pride and attention to detail.
DZRTDAVE
Re: Turtleback Trailer Build - From the Manufacturer
Postby mezmo » Tue Jan 28, 2014 10:13 pm
This will be fun to follow, and a good way for you
to document your process.
Cheers,
Norm/mezmo
mezmo
Images: 194
Postby ssrjim » Wed Jan 29, 2014 11:06 am
I've seen the factory :D
93079
ssrjim
Postby DZRTDAVE » Wed Jan 29, 2014 12:06 pm
We've doubled the Turtleback manufacturing area since you were there. Drop by when you're in the area Jim
DZRTDAVE
Postby ssrjim » Wed Jan 29, 2014 7:20 pm
DZRTDAVE wrote:We've doubled the Turtleback manufacturing area since you were there. Drop by when you're in the area Jim
Cool!
Will do.
93079
ssrjim
Postby DZRTDAVE » Thu Jan 30, 2014 11:23 pm
Well I was going to wait and show each part as it went through the process in order but I just got the floor sections cut today and I was so happy with the job the cutter did. So I had to share a picture.
Dave
DZRTDAVE
Postby KCStudly » Fri Jan 31, 2014 3:02 pm
Laser or water jet?
That is some nice detail with the turtle shell. :thumbsup:
Postby DZRTDAVE » Fri Jan 31, 2014 6:05 pm
Thanks. It's a Laser. I'm thinking about getting a water jet though. More versatile
DZRTDAVE
Postby DZRTDAVE » Sun Mar 02, 2014 4:58 pm
Well I said I'd share how we build our units and here I am. We spent the past month expanding our facility in addition to maintaining some production so It slowed me down on getting this thread started.
In this thread I'm going to share how we build our units top to bottom. For those building your own this may give you a few ideas, for those considering building a trailer you will see what a task it can be and for those on the fence perhaps you'll see that we can offer you a high quality unit for not much more than what you could build one for yourself.
So let's start at the base, the frame. We use all US sourced steel with thickness ranging from 16ga to .188". I built a jig or fixture to fab the chassis up on. Doing this we created a flat and square platform to work from. Just like building a house, if you're not square from the start you're in trouble later when the doors won't close.
Here's a picture of our frame fixture.
Frame Jig.jpg (213.69 KiB) Viewed 1035 times
We cut out steel on a Hyd-Mech manual band saw. This is so much cleaner and quieter than an abrasive saw but most importantly is a true cut every time. We can swivel the head 60 degrees to cut the front of the trailer rather than guessing how long the stick needs to be and cutting it with a skinny wheel.
Hyd-Mech Bandsaw
Hyd-Mech Bandsaw.jpg (201.16 KiB) Viewed 1035 times
60 Degree Cut
60 degree cut.jpg (191.68 KiB) Viewed 1035 times
Well we only get 3 pics per post so I'll end this one and add some more.
Dave
DZRTDAVE
Postby DZRTDAVE » Sun Mar 02, 2014 5:03 pm
I've got a free day today so I'm going to post some more pictures. I'm continuing where I left off. Here's a pic of the 60 degree cut for the nose of the unit.
Big Cut for Nose
Big Cut.jpg (199.54 KiB) Viewed 1032 times
Cut Nose Pieces
Frame Front Cut.jpg (212.67 KiB) Viewed 1032 times
In Place on the Jig
After the nose is cut I notch it for the backbone and front receiver hitch. Pics to follow
DZRTDAVE
Postby DZRTDAVE » Sun Mar 02, 2014 5:08 pm
I have a template that we created to cut a crisp notch on the nose. This is a critical point for the unit so a tight fit is a good idea.
Scribed for the notch
Scribed for the Notch.jpg (174.21 KiB) Viewed 1026 times
Here's a pic after the nose is notched and ready. I cut it pretty close so we dress it out for the final fitment.
Notched Nose
Notched Nose .jpg (182.54 KiB) Viewed 1026 times
Front view of the notch
Notched front.jpg (209.94 KiB) Viewed 1026 times
I like this method of trailer design because all of the parts are integrated. The tongue isn't welded on the bottom like my first unit. This gives better ground clearance and structural integrity.
DZRTDAVE
Postby DZRTDAVE » Sun Mar 02, 2014 5:16 pm
It takes about a day to cut out and prep 5 trailers. When we started it took a day to do one. By getting a better saw that we could gang cut and cut with a quick swivel of the head for the angle cuts saved a whole bunch of time plus we eliminated the calculation and recalculations.
Here's a ready to weld nose
Backbone and Receiver in place
Backbone and Receiver in Place.jpg (198.54 KiB) Viewed 1024 times
Nose Ready For Welding
Nose ready for welding.jpg (197.88 KiB) Viewed 1024 times
Nice Tight Fit
Nice tight fit on the nose.jpg (198.07 KiB) Viewed 1024 times
This sums up the nose on the frame.
DZRTDAVE
Postby Vedette » Thu Mar 06, 2014 4:38 am
Thanks Dave
Can't wait to see more of your build. :thinking:
Good Roads
Brian & Sandi
Good Roads
Brian & Sandi
viewtopic.php?f=50&t=50912
Vedette
Images: 443
